Now I have a problem
Old Nov 24, 2003 | 11:18 AM
Jharger's Avatar
Jharger
I'm trying to remember the assmbly of the cross member. I think this comes completely out then you back the tranny off the motor to clear the clutch then it goes straight down.
Old Nov 24, 2003 | 05:41 PM
my91EXP's Avatar
my91EXP
Forward cross-member
The cross-member is also a carrier for the radius arms. Unfortunately it's fastended to the side rails of the frame with what might be stove-bolt rivets or something like that.
I don't mind splitting the cross-member as it has four bolts inboard towards the center and a set of two bolts on the lower channel of the frame. This gives a little leeway on the cross-member and then the exhaust cross-over can come down the same distance.
I think I might have to resort to a little lateral force to re-install the tranny. After that it's all pretty straight forward.
Incidentally, I'm photographing this procedure as I go along. I noticed you've put together a bit of a help site for enthusiasts, if you're interested I could edit a bunch of them for a 'step-by-step' guide sort of thing.
Anyway, thanks for all your help to date, much appreciated.
Dale.
Buggz_14
Nov 3, 2014 04:45 PM
300-6 AUTO TECH
Jan 18, 2013 07:44 AM
barry s
2004 - 2008 F150
Dec 11, 2010 10:10 PM
Tony G
Jul 15, 2004 01:35 AM
Jim in S. Tx
1983 - 2012 Ranger & B-Series
May 31, 2003 02:31 PM
