F550 questions
Just off the top of my head but a 550 is 19,500 gvwr and I believe the truck would be around 7,500 lbs before upfitting it.
Maintenance cost of adding in fuel filters every 3 oil changes and $30 more oil every oil change.
I would skip the diesel if not towing and go with the 7.3. Quite a bit of cost and power reserve in the 6.7. But then you have to run 4.88s.
If you like Ford, the F-550 - F-600 equivalent (and actually superior in many ways) is the F-59.
The Ford stripped chassis is gasoline only.
If you want diesel, then consider the Freightliner Custom Chassis MT series, that is equipped with a Cummins.
Freightliner Custom Chassis MT Series
You may have to settle on the 6.7 cost.
You could go to a 350 but I think you would be limited to a 9ft bed, maybe there is a solution that is close to your 12 ft need. That can be had in the 6.2/3.73 in a dually.
Someone on here just built the truck you want but in a 350 and I dont know if he was able to get to 12’. I’ll look.
https://www.ford.com/commercial-truc...commercial-vhp
Gets more moderate gearing and lighter axles compared to the 550. Pretty high gvwr options and I would try to stay under 14,000.
Looking at the drivetrain parts on those looks like they are designed to last forever.
We currently have 3 2WD 550's and several 450s. The 450s have boxes on them, 16ft and are gasoline powered (cause the equipment bolted in the 16ft box are gas). Plenty of room, even have the "mom's attic" for the single cab. I don't care to drive them.
Two of our 550's are 17's, 6.7s crewcabs with 11ft flatbeds, the other is a 15, single cab, V10 with 11 flatbed. With this truck if you ride over a dime on the road you will feel it, jarring ride without weight.
I'll only talk about the powerstoke ones now.
Both cabs are comfortable for XL's with power group, Bluetooth, steering wheel controls.
The one is 19.5 GVW/4:88 gears and has about 90K. Truck is used heavy towing/hauling. The truck sits alot at our wearhouse. Other than regular maintenance, and one set of steer tires, it's been trouble free. It is one current problem I'll talk about later. The ride is bouncier the the other 17.
The other is basically my daily driver. It's a 18K, with 4:30 gears. Currently about 240,000 miles, 7600 hrs, 3000 idle hours. I travel all over the country with this truck often over 45K with my largest gooseneck trailer. It's been a good truck, 3 set of batteries, 4 set of tires, 3 fuel tanks, on 2nd set of brakes. Other than 7500 oil and fuel filters every 15K, it's been/is a great truck. Normally we replace at 200,000, I believe it will be 500K on this one.
My normal weight is 11K with 240 gals of fuel, and rides extremely well even when both my drop tanks are empty.
I've personal own 17 SD's since 99, currently have a lariat tremor, I prefer the 550 overall for comfort (sounds silly, right)
The only defect I've found is the fuel tank collapsing under heavy loads, when you are only getting 3 MPG for long periods of time. (Grossing over 40K).
The 6.7 is a solid motor, same with the 6 speed. Currently only have 3 350's with the 10 speeds and have been fine with 16K trailers, so I can't comment on the 550's with 10 speeds.
