Sponsored by: Real Truck
CeL codes POOBD and P054e
Old Nov 7, 2021 | 01:02 PM
Speedybug63's Avatar
Speedybug63
Trailering
I'm getting these codes now. Truck seems to run fine regardless but still concerned. Fully deleted. Running MDP non vgt turbo with AMDP SOFL tunes. Codes pop up when I get into the boost. Truck is a 2013 f250 running in COLORADO. Research shows mass air flow on the 1st sp I'm not terribly concerned about that but the other shows possible low pressure fuel pump. Any pointers to actually find the issue?
Old Nov 10, 2021 | 11:34 AM
Speedybug63
Trailering
Anyone?? Surprised nobody has a thought on this
Old Nov 10, 2021 | 12:30 PM
Mike1's Avatar
Mike1
Have you used a fuel pressure gauge to see what it's doing? If your truck has a bunch of miles the fuel pump might be getting weak, I don't know much about diesels but maybe weak ump, filters becoming slightly clogged?? A suggestion would be to plug in a scanner and watch your live data. I'm sure the more knowledgeable folks will chime in soon.
JOHN2001
18
Oct 3, 2013 04:17 PM
ford 55
Jun 20, 2012 11:13 AM
bwilliam7
Sep 29, 2010 07:22 AM
Chorizo520
May 2, 2007 10:53 PM
