The hype is real! Centramatic balancers
Old Nov 6, 2021 | 10:34 AM
morehouse7's Avatar
morehouse7
Put these on a couple weeks ago and hadn't been on the highway yet to test out the "higher speed sweet spots" in which I usually get vibrated.
Smooth as glass, I don't know why more people don't run these? It's a no brainer in my book and the price is more than fair. Their customer service is A+ too.
For reference-
I took off all my weights and the most one wheel had was 4.75. I watched a review where the guy in the vid said my models were good for up to 6 oz.
Old Nov 6, 2021 | 11:25 AM
Section179's Avatar
Section179
Recommended place to order? Srw or drw?
I’m just starting to get a hint of death wobble related to tire balance (and a bad stabilizer of course) and have been thinking about these at the same time I do the tires and stabilizer.
Old Nov 6, 2021 | 12:34 PM
morehouse7's Avatar
morehouse7
I have a SRW CCSB. 33x10.5 R17 Kenda Klever R/T
I bought them directly from Centramatic. They took awhile to get, like 2 weeks. They are very responsive via email if you have questions.
Old Nov 6, 2021 | 03:26 PM
jfcody3962's Avatar
jfcody3962
why remove the wheel weights? just for looks?
Seems to me, the CMs would work best if the wheel and tire are at least close to already balanced.
Old Nov 6, 2021 | 04:47 PM
morehouse7's Avatar
morehouse7
Nah not really looks, more to see what the result was. I think balancing is still a skill and to totally remove that human factor is a win. I can mount my own tires now and not take them anywhere to have them balanced. There's always the chance of having a jacked rim or tire that these won't iron out but I'll worry about that on my next sets. In that case the CMs may need to have the weights on to correct the issue, or go with a larger CM.
Old Nov 7, 2021 | 05:06 PM
Crotchety Ford truck only's Avatar
"I think balancing is still a skill" Even if you ask them to rotate the rubber on the rim to offset heavy spot on rim and tire to rim they might only do it once, and if they were real diligent and got it to the smallest weight possible it wouldn't be economical for them unless you pay for it. I hate to see a lot of weight on A/T or regular tires.
Old Nov 7, 2021 | 10:17 PM
brandon4's Avatar
brandon4
I have Centramatics on my 450. They are awesome. So much nicer to drive.
Old Nov 7, 2021 | 10:30 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I've run Centramatics for over a decade on a truck with the same set of tires that I've also run for over a decade... with hardly any tread wear, and no rotation.
That's the problem with Centramatics. The dynamic balancing helps preserve tires for so long... one can't justify changing tires on a whim. The tires don't wear out.
Old Nov 8, 2021 | 06:38 AM
last5oh_302's Avatar
last5oh_302
Good to know. I may have to order a set if I ever get the truck. I'll see how it rides first.
Old Nov 8, 2021 | 06:39 AM
JohnD333's Avatar
JohnD333
Agreed. Never a vibration or wobble, but bilsteins all around including dampener never hurts.
87,0000 miles on 350 dually oem BF Goodrich tires. Most of that was with a 3800# pin 5th wheel. The rears were never rotated and worn to 3/32; fronts better because I rotated to include spare. But swapped all at once.
I left my oem balance weights in place (the rim clear coat is damaged by removal). replacements used glue on weights.
Old Nov 8, 2021 | 09:06 AM
pig9r's Avatar
pig9r
I have been contemplating getting a set but not sure how they would look with the black appearance package wheels?
Old Nov 8, 2021 | 10:14 AM
morehouse7's Avatar
morehouse7
I painted mine black because of the gray rims, maybe you paint to match the rotor color or leave them? It may give you a visualization, or not..
They'd be easy to sell if you decide not to keep them.
https://www.ford-trucks.com/forums/1...installed.html
Old Nov 8, 2021 | 11:36 AM
riverratrusty's Avatar
riverratrusty
For reference-
You pushed me over the edge... I have been fighting balance issues on my truck (35's). It's great until highway speed, especially if it's warm. It's not bad but on a smooth road the truck should be like glass in my opinion. Every time I have the tire shop re-balance they tell me 2 or 3 of them were out. So after this post and others I ordered mine today. I'll share my experience once they arrive and I install them,
Old Nov 8, 2021 | 01:10 PM
morehouse7's Avatar
morehouse7
You'll be happy I'm sure. My next set will be 35s or 37s so I figured might as well do it now. I was at my cousin's dairy farm yesterday and he was complaining about balance beads on his CC dually duramax he hauls his equipment with and he's ordering some. Like I said, shocked more people don't know about them.
Old Nov 8, 2021 | 01:34 PM
BrokeDown56's Avatar
BrokeDown56
In FL, we just throw a shovel full of sand in the tire. Problem solved!!!
My motorhome had sand in the front tires. It was put in by the folks that rotated the tires,
So, while the above is very true I plan on getting these for my F450... if it ever comes in.
Is adaptive steering trucks being shipped yet????
