Left Front Wheel Speed Sensor
Old Nov 5, 2021 | 09:41 AM
OConner96's Avatar
OConner96
Exclamation Left Front Wheel Speed Sensor
Hello guys and gals. Im having some issues with my 2010 f150. I had replaced most of the front end ( Spring/struts , upper control arm, inner & outer tie rod, Lower ball joints, Sway bar linkage ) But in the process I broke the left front speed sensor in the process as it was seized in the wheel hub but i was able to get it out with a little work. How ever I replaced it with a new one and now the Brake light, abs, and traction control light is coming on. Ive tried resting with my code reader, Did the compositor discharge (disconnect the battery and connect the positive and negative together to drain system of all charge). Ive even went back pulled the sensor cleaned it and the connector under the wheel well. The Codes I keep getting is B1596, C1296, U0418, P1000
lbiffin
Mar 24, 2015 09:18 AM
Cilvers
2009 - 2014 F150
Nov 30, 2014 12:20 PM
Dutter 2
1997 - 2003 F150
Oct 12, 2013 02:28 PM
boffah
Aug 22, 2004 10:27 PM
