Replacing rear tail light assembly
Old Nov 5, 2021 | 08:49 AM
waggs's Avatar
waggs
Searched around, not much on this forum related to replacing a rear tail light assembly. I have a 2020 Superduty, I cracked my passenger side rear LED tail light assembly which has bliss. As best I can tell, I can buy a replacement and swap out the metal part on the backside of the new one with the one from my truck and it should work without having to take it to a dealer to get the truck to recognize the new assembly?
Old Nov 5, 2021 | 09:18 AM
black08's Avatar
black08
Correct, I just had to replace my drivers side taillight. It is a quick fix and no need to go to the dealer.
Old Nov 5, 2021 | 09:30 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
The "rear taillight" huh?
Is there a "front taillight"???
Just couldn't pass that one up!
Old Nov 5, 2021 | 10:18 AM
1980CJ7's Avatar
1980CJ7
No, but there is a "Center High Mount Stop Light, Lamp Assembly - Rear - High Mounted" I don't know why Ford uses such superfluous descriptions.
https://www.fairwayfordparts.net/oem...Y4LWdhcw%3D%3D
Old Nov 5, 2021 | 10:27 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
What was the total cost for you to repair / replace your driver's side taillight?
Just to confirm, since your post did not state... Are your taillights LED and do they have BLISS, like those of the OP?
Old Nov 5, 2021 | 01:59 PM
black08's Avatar
black08
Yes, they are the led lights with BLISS. I bought the part through a buddy that runs a local repair shop, the assembly was around $1000.00 ( Canadian ). I swapped out the BLISS unit from the old one and put it in the new one myself.
Old Nov 5, 2021 | 04:35 PM
powerboatr's Avatar
powerboatr
on my 2021 i crunched the driver rear light assembly, by backing into a tree at the hog lease. it was dark and ...well you know
there is no parts swap for the inerds, i had to buy a whole assembly at around 800 buckaroos. fairway ford had them on their ebay site
you would have to break the lenses apart to swap out the internals if you look at how they are built
747Driver
2015 - 2020 F150
Nov 28, 2021 04:16 PM
JD BuckSavage
Apr 16, 2017 04:06 PM
WolfFox
Feb 9, 2017 08:43 PM
cullenkyla
2015 - 2020 F150
Oct 4, 2016 05:42 PM
flya750
2004 - 2008 F150
Jul 21, 2006 08:19 PM
