Looking for info on where I can find a replacement tail light assembly for a 2018 F-150. Had a fender bender where only our tail light had the lens broken and it appears that it is integrated into the assembly.
I would compare the dealer, junkyard, and online OEM Ford places to pick one that perfectly matches your other factory tail light.
I can't think of the name, but there is an online dealership people sometimes mention as having better than normal prices.
Someone might be able to chime in on the name.
Any help is greatly appreciated.
Check out Fairway Ford out of OH.
They also have an eBay store and many times offer free shipping.
You didn’t mention which one you have but Fairway Ford will have the OEM LED or halogen assemblies.
Also downbload the app Row52. You can check 'junk yards' for inventory. Might get lucky since most vehicles that show up there are wrecked in the front.
Around here there are a couple of "Pick & Pull" places where you can wander around and pick the part you need off the wrecks in the yard. Often (but not always) a fair deal.
My 2018 F150 Drivers side is filling with water. Drivers side is a hundred Dollars more the the passenger side. I think they know there is a problem. My local dealer would not resolve the issue, but told me to go back to the ford dealer I bought it from.
Plugged vents at the bottom of the door. Water seeps though the window seal. open the door and you can find the vent holes along the bottom seam run a small wire or a pipe cleaner up into them. Some people take a flat tip screwdriver and open them up a little more.
TJ
I hate to say it but Facebook Marketplace. I got a clean pair of tail lights delivered for under $50 for my '15. My lights are non blind spot sensor. Those are $300+ea.
