Fuel gauge question
Old Nov 4, 2021 | 02:56 PM
sandymane's Avatar
sandymane
Fuel gauge question
Before I get into diagnosing any electrical problem that I may not have, this is what is going on.
Recently I let my front tank get low and when I put fuel in it, it took some time before the gauge started showing fuel level.. Today I added about 10 gallons to the front tank and it registers empty. Because of the first experience, I assumed I had a bad float. So I goosed the truck and hit the brakes hard to slosh the fuel and the gauge went up to about half full and returned to empty. Repeated that several times with the same results. So I assume my front tank float is sunk or partially stuck. I have not changed the FDM in either tank since I got it at 87K. It has about 95K on it now. Truck runs fine on either tank so is it probably a stuck/sunk float? Thanks for any opinions. Sandy
Old Nov 4, 2021 | 05:08 PM
SFaulken's Avatar
SFaulken
That would be my guess. Yeah.
Old Nov 5, 2021 | 06:37 PM
sandymane's Avatar
sandymane
Added a little MMO to my front tank with the stuck float. I have been using Hurricane "Just in case" generator fuel since we are now out of season. Fuel had Stable in it but ...... After about 20 minutes of driving today with the MMO the float came unstuck and rose to the proper level. I don't know if the MMO worked or just time but it is working now. Thanks for the reply SFaulken and rla
Old Nov 5, 2021 | 09:24 PM
SFaulken's Avatar
SFaulken
Heh, MMO is what I would have suggested, I've seen it "resurrect" more fuel gauges and low pressure pumps on the bricknoses than I can count. Dunno whats in it, or why it works, but I always try it before changing pumps or sending units.
884x4broncoII
Dec 23, 2013 06:54 PM
edub32
Jul 6, 2009 04:05 PM
garysi
Bronco II
Jun 26, 2004 08:23 PM
canuck999
Feb 29, 2004 04:56 PM
Truckboy
Dec 12, 2003 11:21 AM
