New Sync 3 Issue
Old Nov 7, 2021 | 01:34 PM
CT-Mike's Avatar
CT-Mike
Originally Posted by 4wd6.7L
Both your Sync and Navigation are older versions.
My truck does the same, a scan while connected to WiFi never shows any update available when in fact there is. I have read of others experiencing the same.
I have updated twice since 2019 and both times had to go online, input my VIN to check for updates, then download to a USB.
https://help.ford.com/update-sync/
Edit- I have no idea why my links aren't clickable so often on this forum. If you qoute my post, for whatever reason it will become clickable.
Thanks, I’ll find a thumb drive and download the latest updates and report back.
Old Nov 7, 2021 | 03:12 PM
CT-Mike's Avatar
CT-Mike
Well I did the update and it seems to have fixed the issue. One question though - when I look at the About Sync screen, it still says Software Version 3.0 Build 19205_Product just like it did before the update.
What gives?
Old Nov 7, 2021 | 03:16 PM
4wd6.7L's Avatar
4wd6.7L
That's strange, it should show the new version that you loaded. Might require a shut down(key off) first. I found the update to be pretty fast, no more than 10 minutes, you could try again.
Old Nov 8, 2021 | 08:22 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
What gives?
If the key cycles don’t fix it try a soft reset
power+FF
ZooDad
Old Nov 27, 2021 | 07:13 PM
CT-Mike's Avatar
CT-Mike
So it seems that updating the Sync version didn’t fix the pop up issue after all. So I brought it in to the dealer to fix that issue, along with repeated front collision not available warnings, and to get one of the sealed batteries replaced due to leaking.
The front collision issue was fixed via a software update, and the issue with the Sync pop up was my as-built wasn’t on their (Ford’s?) server. Was I supposed to upload my configuration after making changing in Forscan?
Old Nov 27, 2021 | 07:23 PM
4wd6.7L's Avatar
4wd6.7L
I have not heard of doing that. So how did the dealer go about fixing it? I have been getting a pop up almost evertime the truck is restarted. Nothing is in the USB drive and wifi updates are turned off. I have even tried doing the Sync update a couple more times...still pops up.
I just close it out, have yet to find any features disabled.
Old Nov 27, 2021 | 08:10 PM
CT-Mike's Avatar
CT-Mike
The service writer didn’t give me a lot of details - just initially that they were waiting to hear back from the Ford Hotline, and then that they had to upload my configuration file to their servers.
Hapspkp
13
May 22, 2020 06:38 PM
hilfikerkg
2015 - 2020 F150
Nov 12, 2019 07:35 PM
Cobravii
Mar 4, 2019 09:44 PM
bobj49f2
Sep 13, 2014 09:09 PM
80351
Maryland Chapter
77
Jun 30, 2008 09:35 PM
