Replacement Horn Options
Old Nov 4, 2021 | 12:36 PM
GreenMtnMan's Avatar
GreenMtnMan
1987 F-250 original horns are shot. Not finding any aftermarket ones. It's the one with the Hi & Low horns on a Y shaped bracket just behind the left headlight.
Old Nov 4, 2021 | 12:55 PM
Hit Man X's Avatar
Hit Man X
Fiamm has high and low. I use the 'freeway blaster' for a bit louder output. Maybe $30 or so
Old Nov 4, 2021 | 03:36 PM
sandymane's Avatar
sandymane
These from Fiamm look like a direct bolt on for my 91. On the product description section it says they are a direct Ford OEM replacement. Nice
Amazon Amazon
Old Nov 4, 2021 | 05:33 PM
wwhite's Avatar
wwhite
I have a couple of stock original hi/lo horns from 1994, they are Flamm brand.
Old Nov 4, 2021 | 05:51 PM
McLeod's Avatar
McLeod
I took some orig. horns out of a wrecking yard 1994 F150 and easily bolted into my 1966 Bronco.
Vast improvement in tone and loudness over the earlier horns.
One bolt and it is in and the used horn was only $10 or $15
Old Nov 5, 2021 | 01:13 AM
TexasGuy001's Avatar
TexasGuy001
What about some that are actually louder with a bold sound to them? Thought about finding some old horns like the tri horn setup from Cadillac in the 60s or the later tri horn setup that was on some Cadillac and Buick cars. I don't think Ford ever offered any such thing. Not interested in juvenile air or train horns.
Old Nov 5, 2021 | 06:48 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Fiamm shows on their site the 'Freeway Blaster' is 8dB louder than their standard horn. Seem to work fine for me when I install them on various vehicles, best was being rid of that weenie high pitched horn on my '05 Civic run-a-bout for the Freeway Blaster set. Now it actually sounds like a truck and has stopped people twice.
My pal swapped in Buick full size horns on his Geo, it is pretty funny.
Old Nov 5, 2021 | 10:05 AM
SFaulken's Avatar
SFaulken
You know, I don't even care if my rigs *have* a horn. I'd never use the damn thing. My CJ and my hotrod don't have them. I know the one on my '75 doesn't work, I have *zero* clue if the one on my '87 works or not.
Old Nov 6, 2021 | 06:28 PM
McLeod's Avatar
McLeod
Hahaha... don't like these Beavis and Butthead types huh?
These little pukes are lucky they don't get pounded on.
Old Nov 25, 2021 | 07:21 AM
GreenMtnMan
Just to follow up on this, I ended up using Fiamm horns from the local NAPA. I think the part numbers were 1055 & 1054.
Old Nov 27, 2021 | 11:49 PM
TexasGuy001
https://www.youtube.com/watch?v=xTQaWs1inRI
https://www.youtube.com/watch?v=v8yN...l=Hornblasters
Yep, all of that stuff is for delinquents and posers. There is no reason to have a train horn on a pickup truck.
Old Nov 27, 2021 | 11:50 PM
TexasGuy001
Are those basically stock replacements or are they louder or bolder sounding?
Old Nov 28, 2021 | 08:16 AM
GreenMtnMan
I don't know, I had not heard the originals for so long. They probably are louder & sound pretty good. An earlier poster commented that he didn't even know or care if his horns worked. (I'm thrilled). Here in Vermont you must have a functioning horn to legally pass a state inspection. Also if I were to witness someone about to back into something (or Heaven forbid) someone, I want to be able to try to get them to stop.
Old Nov 28, 2021 | 12:12 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
They are louder, same notes. That is it, cost is nearly the same.
Old Nov 28, 2021 | 11:36 PM
raystankewitz's Avatar
raystankewitz
You need a horn, and not just a squeaky little one if you plan to drive the 465 Loop around Indianapolis or the 69 from Indy to Muncie. Too many boneheads paying no attention to the road, totally engrossed in their cellphones instead. We put the freeway Blasters on the wife's 2005 Explorer to replace the soggy sounding things Ford put on it, a huge improvement. I'm putting air horns on my truck, something like you would find on a European bus. Not an annoying loud, just a "Look Out, Idiot!" loud. People around here are so out of it, just a few days ago, somebody pulled out of a side street that had clear views, broadsiding a fire truck headed to a call Code 3. that kind of out of it.
