Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
TPMS Receiver/Module location?
Old Nov 3, 2021 | 07:17 PM
accent2010's Avatar
accent2010
Where is the TPMS Receiver/Module located of 09 Ford Escape?
Old Nov 3, 2021 | 08:11 PM
Torky2's Avatar
Torky2
According to the 2010 shop manual, the TPMS receiver is integral to the SJB (Smart Junction Box), which is in the center console. Section 204-04 has procedures and DTC codes for different faults and troubleshooting procedures. I believe an SJB needs to be programmed vs. VIN number to turn on correct features in an SJB that are needed by a specific vehicle's equipage, so a simple swap-out of SJBs causes problems unless by luck one could find an exact programmed SJB. That is the extent of my knowledge on the TPMS receiver-side.
Old Nov 3, 2021 | 08:42 PM
accent2010's Avatar
accent2010
Does it have an antenna. If yes, where is the antenna located? Thanks!
Old Nov 4, 2021 | 06:25 AM
projectSHO89's Avatar
projectSHO89
The antenna is internal to the SJB.
What problem are you trying to solve?
Old Apr 6, 2023 | 04:28 PM
accent2010's Avatar
accent2010
It won't re-learn new TPMS sensor although the sensor test good with Autel tool.
Dale Massey
Aftermarket Products
Jan 31, 2019 10:14 PM
CSDenny
Dec 2, 2017 09:15 PM
txazguy
6.7L Power Stroke Diesel
Mar 24, 2017 04:47 AM
04F-250mark
Mar 7, 2012 11:32 AM
