Annuder Vibration Question
Old Nov 2, 2021 | 03:51 PM
rcwarship's Avatar
rcwarship
Hi All,
I was hoping to get your help with some ideas on Betsy's problems - LOL, everyone names their truck, don't they?
Details - 1986 F150 4.9L manual 5-speed, 2WD. 140,000 miles, Washington state truck - minor surface rust.
  • It always vibrates at 68+ mph, most of the time while in neutral and coasting to a stop sign while at lower speeds, sometimes while accelerating 20-45 mph.
  • No vibration through steering wheel
  • I don't see any shiny spots/broken welds for balance on the drive shafts (twin shafts with slip fit & carrier bearing).
While coasting to a stop, it's vibrating while in neutral & with the clutch not depressed:
  • With the clutch depressed, it still vibrates
  • When put in gear (clutch pedal still depressed) - vibration quits
  • May or may not vibrate on acceleration, mostly not
To date:
Truck jacked up & wheels spun/rocked, they look good. There's no bearing noise, they spin for a while, no undue drag - I don't think that wheel bearings are the issue.
I'm thinking that u-joints & the carrier bearing are the next step - any other ideas?
Thank you in advance,
Jon
Old Nov 2, 2021 | 04:00 PM
Conanski's Avatar
Conanski
Weak/broken engine mounts perhaps, does the shifter move to the side a lot when you're on the gas vs coasting?
Old Nov 2, 2021 | 04:55 PM
rcwarship's Avatar
rcwarship
Thank you Paul, I didn't think to check the engine mounts - did get the transmission mount checked, with no problems found. I'll get on the engine mounts & see if they're an issue.
Gracias!
FinallygotaOBS
13
Jun 4, 2019 09:44 AM
Chipper45
Apr 17, 2017 08:37 PM
EMD_DRIVER
15
Jan 19, 2009 04:57 PM
jarch
19
Mar 1, 2001 03:26 AM
