E4OD
Old Nov 5, 2021 | 10:03 AM
  #31
00t444e's Avatar
00t444e
Originally Posted by Ashiver34
So what gears would go with my truck with it being a 8.8 and the panel saying i have a 18 code what would fit?
For 35s 4.56 gears.
Old Nov 5, 2021 | 10:10 AM
  #32
SFaulken's Avatar
SFaulken
Yeah, with 35's and the setup you've got, I'd go 4.56 or 4.27 (no idea if 4.27's are available for the 8.8 or not.)
Old Nov 5, 2021 | 10:37 AM
  #33
Ashiver34's Avatar
Ashiver34
my motor is also rebuilt at a 100k now has 260k on it it has a low restriction air box with a k&n air filter and a set of dual 45 straight pipes no cats or muffler 3 inch pipe 3 1/2 in tips
Old Nov 5, 2021 | 10:40 AM
  #34
SFaulken's Avatar
SFaulken
Doesn't matter, unless you've done something to up the compression, or changed the cam to move where horsepower and torque are maxed out at, Stock numbers are still going to apply.
Old Nov 5, 2021 | 10:41 AM
  #35
Ashiver34's Avatar
Ashiver34
it was bored 40 over btw
Old Nov 5, 2021 | 10:53 AM
  #36
Ashiver34's Avatar
Ashiver34
and on the gears im going to go to the junk yard tomorrow what truck should i look for to pull the diff out of
Old Nov 5, 2021 | 10:58 AM
  #37
SFaulken's Avatar
SFaulken
You won't find anything deeper than 4.10's in the junkyard. And they might exist, but I've never seen a factory 8.8 with 4.10's
For the sort of gearing that's being discussed, you'd need to go aftermarket.
*most* of what you find in the junkyard is going to be 3.08s or 3.55s in my experience.
Old Nov 5, 2021 | 11:05 AM
  #38
rla2005's Avatar
rla2005
You may have increased the TQ slightly with the exhaust. That K&N hot air intake system makes a pretty piece of wall art or trash can weight. If the compression is stock and the cam is stock specification you are still in 260 lb./ft. of torque range. Perhaps you bumped it to 270. Hard to say, but you are ahead of a completely stock truck with aged exhaust components.
Gears are going to have to be sourced then installed in your rear carrier.
Old Nov 5, 2021 | 11:10 AM
  #39
00t444e's Avatar
00t444e
8.8s with 4.10 gears were common in Rangers and Explorers with the 4.0.
Old Nov 5, 2021 | 11:13 AM
  #40
SFaulken's Avatar
SFaulken
Ahhh, I didn't even think about Rangers or Explorers.
Old Nov 5, 2021 | 04:54 PM
  #41
Ashiver34's Avatar
Ashiver34
I really just need something temp until i can order a 4:10 or higher offline so would 3:55 help until then?
Old Nov 5, 2021 | 05:00 PM
  #42
SFaulken's Avatar
SFaulken
It's your money, do what you want, but it seems like a waste to me.
You might get *very* lucky, and be able to pull the ring and pinion from a used source, toss it in yours, and not have to shim anything, but it's not bloody likely. Bare minimum, usually when changing a ring and pinion, you're going to need to be replacing the pinion bearings, crush sleeve, and pinion nut. So if you like buying parts more than once, That's entirely up to you.
Old Nov 5, 2021 | 05:02 PM
  #43
Ashiver34's Avatar
Ashiver34
got it and 1 more thing im looking into a spartan locker do yall know if its any good or not worth it?
Old Nov 5, 2021 | 05:07 PM
  #44
SFaulken's Avatar
SFaulken
In a stock level of horsepower? A lunchbox like the spartan will work fine. You'll be very unlikely to break it.
That being said, if you've never driven a rig with a locker before, especially on things like Icy roads, they do take a bit of getting used to.
Old Nov 5, 2021 | 05:21 PM
  #45
Ashiver34's Avatar
Ashiver34
I live in Florida so no need to worry about snow shes gonna be my dd and huntin rig
