my motor is also rebuilt at a 100k now has 260k on it it has a low restriction air box with a k&n air filter and a set of dual 45 straight pipes no cats or muffler 3 inch pipe 3 1/2 in tips
Doesn't matter, unless you've done something to up the compression, or changed the cam to move where horsepower and torque are maxed out at, Stock numbers are still going to apply.
You may have increased the TQ slightly with the exhaust. That K&N hot air intake system makes a pretty piece of wall art or trash can weight. If the compression is stock and the cam is stock specification you are still in 260 lb./ft. of torque range. Perhaps you bumped it to 270. Hard to say, but you are ahead of a completely stock truck with aged exhaust components.
Gears are going to have to be sourced then installed in your rear carrier.
It's your money, do what you want, but it seems like a waste to me.
You might get *very* lucky, and be able to pull the ring and pinion from a used source, toss it in yours, and not have to shim anything, but it's not bloody likely. Bare minimum, usually when changing a ring and pinion, you're going to need to be replacing the pinion bearings, crush sleeve, and pinion nut. So if you like buying parts more than once, That's entirely up to you.
