Keyless entry pad wiring diagram needed...
Old Nov 2, 2021 | 05:09 AM
MightyDuc's Avatar
MightyDuc
4wd Low
Hi, everyone. New excursion owner here (2005 EB 6.0 4x4). I bought the truck from Copart about two months ago and am slowly working my way through a few "surprises" I've discovered since it showed up in my driveway. I love the convenience of the keypad on the driver's door, but mine doesn't work. I pulled the interior panel to investigate and discovered that it's missing the short ~12" cable that connects the plug on the back of the keypad to the round, 8-pin connector inside the door. I know these keypads are on virtually every ford vehicle since the late 90s so I made a trip to my local Pull-A-Part. No Excursions available, but I did manage to find the proper plugs for each end of the missing cable. The problem is that they have a different number of wires in each plug. Electrical issues definitely aren't my specialty but I think I can make it work if anyone has a wiring diagram they wouldn't mind posting. For what it's worth, I've done tons of searching on this topic and checked the Tech Folder, but the "wiring diagram" link appears to no longer be valid.
On a different note, where do you guys go when you need part numbers and diagrams? Ford's parts website is TERRIBLE!
Thanks in advance for the info!
Old Nov 2, 2021 | 06:40 AM
alloro's Avatar
alloro
This PDF has the keypad wiring diagram and the connector face/pinouts for each of the connectors. Be sure to compare the circuit numbers (not the pin numbers) and not just the colors when making your connections.
File Type: pdf
Old Nov 2, 2021 | 09:38 PM
MightyDuc's Avatar
MightyDuc
4wd Low
Awesome. Thank you very much, alloro! The first page of that pdf looks like Greek to me, but I should be able to decipher it with a little help from Google.
Old Nov 3, 2021 | 10:34 AM
alloro's Avatar
alloro
To the left of where it says C510 in blue are 5 wires. The number next to each wire (6, 5, 2, 1, 4) are the pin numbers on connector C510.
To the left of where it says C500 in blue are 5 wires. The number next to each wire (2, 6, 1, 3, 7) are the pin numbers on connector C500.
The same pattern holds true for the ground wire coming off the bottom of the keypad assembly
Refer to the included connector C500 and C510 pin faces to determines which pins are which. All in all you will be connecting only 6 of the 8 pins on each of the two connectors, the extra 2 pins are not used.
Old Nov 8, 2021 | 09:33 PM
MightyDuc's Avatar
MightyDuc
4wd Low
Thanks for the detailed explanation. Happy to report a successful fix! Very much appreciated!
Old Nov 9, 2021 | 07:16 AM
alloro's Avatar
alloro
Good job!
Old Jun 7, 2025 | 07:37 PM
Bighoud's Avatar
Bighoud
1st Gear
C500 pin
hello, need help with c500 plug for keypad. Is the commun white wire is the 12v wire?
want try to use this keypad in my winnebago
Thanks
Old Nov 9, 2025 | 06:53 AM
txstimmy's Avatar
txstimmy
2nd Gear
I know this is an old dead thread but im trying to find the same part and cannot. any help?
KingRanchMama
Electrical Systems/Wiring
Jul 16, 2018 01:19 PM
Jarryd
Jan 1, 2014 02:09 PM
Deak
Jun 23, 2006 04:25 PM
PHEREMONEFACTORY
Nov 11, 2004 11:37 AM
CrazyFordMan
Apr 19, 2003 11:44 PM
