Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Vin decode help
Old Nov 1, 2021 | 07:35 PM
Jd6620's Avatar
Jd6620
Vin decode help
Title says 1978 n700. Vin # N70EVCF2929 anyone can help me decode this would be greatly appreciated to make sure I have what the title says and to find out what engine. I'm trying to get the right parts for it and No one can pull anything up when they use the vin. Thank you very much
Old Nov 1, 2021 | 08:36 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Might have better luck to ask the "big" truck folks. https://www.ford-trucks.com/forums/forum232/
Old Nov 2, 2021 | 01:02 AM
85e150's Avatar
85e150
Welcome to FTE. Moved to Large Truck.
N70 = 1973-on LN700 gas
E = 361 4V XD FT gas V8. They added "XD", taking the place of HD and for smog reasons also, maybe.....
V = Kentucky Truck Plant
CF2929 = 1978 numerical series
Is there a warranty plate on the door? That has transmission and axle and other info that can be decoded all for one low price.
OP has posted the tag below and so we continue:
202 = 202 inch wheelbase
M = White
N702 = LN700 gas, 23,000 lbs GVWR
8A8 = Standard cab without butterfly hood. I do not have uphostery or seat type info.
BM
B = This is usually an auxiliary transmission code. For '78 it is: "Fan clutch less sound package or engine less Calif. emissions"
M = Clark model 285V five speed direct transmission
52H
52 = Rockwell (Timken) model H-172 single speed rear axle, 17,500 lbs capacity, 5.83 ratio
H = Ford 12,000 lb capacity front axle, with a note saying: "Tire carrier with manual steering-with steer-ease".
23000 = 23,000 lbs GVWR
41 = Chicago District Code
If something doesn't line up, let me know and I will double check.
Old Nov 2, 2021 | 08:03 PM
Jd6620's Avatar
Jd6620
Vin decode help
Here is the vin any help figuring out the rest of numbers would be greatly appreciated. Thank you.for all the help
Old Nov 2, 2021 | 09:05 PM
85e150's Avatar
85e150
Post moved, decode completed for the moment.
Kjh6
Large Truck
Aug 10, 2021 11:45 PM
fslay
Large Truck
May 24, 2021 03:58 AM
