Trying to replace this carb purchase the replacement it was wrong it appears to be a 2100 with a 121 Venturi the motor is a 351 Windsor supposedly from a mid-80s LTD All The replacements I found don't have electric choke or the pull down choke any ideas ?
As far as I recall the only mid 80s LTDs that could get a 351W were police cars, Try looking at Econoline 351W carbs 1975 and newer. You may strike oil.
Thanks for the reply! That's what I was told was it was from a old police car, anyway the only one I've found that is the same comes from a 72 f250 with a 6.4 390, is there any issues or benefits buying another one that's the same ? I don't want to foul plugs using a bigger carb, thank you !
Not really sure what information your looking for. All 2100/2150 carbs can be setup to run electric or manual operation with a conversion kit. A 1.21 venturi carb is a 1.21 venturi carb no matter what size motor it was on. A 1.21 or 1.23 sounds like the right size for your 351.
