DRL Not Working
Old Oct 26, 2021 | 09:12 PM
dugals's Avatar
dugals
DRL Not Working
On the dash instrument cluster, the Daytime Running Lights box is checked but there are no lights. Anyone else having this problem or am I overlooking something?
As an aside I hooked up my 7,700 GVW (6,500 net weight) and towed it to the inspection station and the 7.3 was fantastic. Can’t wait to take an extended trip. I’m excited because I waited 5 months for this jewel. Cheers
Old Oct 26, 2021 | 09:25 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Headlight switch set to auto?
Old Oct 26, 2021 | 09:38 PM
chadstickpoindexter's Avatar
chadstickpoindexter
I believe they only come on when in drive too.
dugals's Avatar
dugals
No. The manual doesn't say anything about being in auto mode.
Old Oct 26, 2021 | 09:55 PM
4wd6.7L's Avatar
4wd6.7L
LED, or halogen? I know the LED drl's only come on when the switch is set to auto and shifted out of park. Halogen may be the same.
Old Oct 26, 2021 | 10:02 PM
dugals's Avatar
dugals
I have LEDs and I was shifted into Drive. All the other vehicles I've owned including a 2020 F150 with LEDs have not required auto mode. I don't understand.
Old Oct 26, 2021 | 10:22 PM
4wd6.7L's Avatar
4wd6.7L
Not sure what to tell you but here is the DRL section from the manual. Also, the DRL's are only the outer portion (bars) of the headlight (unless that has changed in recent years).
Old Oct 26, 2021 | 10:30 PM
dugals's Avatar
dugals
You are correct - it must be in autolamps position - bummer!! Like I said before - I don't understand. Thanks
Old Oct 26, 2021 | 10:42 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I knew it had to be set to auto, hadn't recalled that it had to be out of park.
Mike1
Oct 10, 2017 03:51 PM
radical_reabster
Jul 17, 2017 11:21 PM
97 ford 7.3
Feb 28, 2013 11:30 PM
Ranger-go-Boom
1983 - 2012 Ranger & B-Series
Nov 21, 2005 10:58 AM
thedettras
Electrical Systems/Wiring
Dec 1, 2003 11:53 AM
