instrument cluster
Old Nov 3, 2003 | 01:41 PM
daveengelson's Avatar
daveengelson
instrument cluster
Any help would be appreciated,
have 65 f100 std cab w/ metal instrument panel. Want to repaint the surface but not sure how to remove the gages. There is an alt. and oil pressure gage about 2 1/4" dia. on each side of speedometer.
It appears you have to pry the chrome face rings off to get the gages out. Fearful may damage if incorrect, so thought before taking screw driver to it would check and see if anyone has done it.
thanx,
dave
65 f100,flareside, 302, 4 speed, ps/pb
65 f100, custom cab, styleside, 390, 3speed/o.d., pb
Old Nov 3, 2003 | 02:04 PM
tasdad's Avatar
tasdad
Good question. I just got finished doing my '65 Custom Cab instrument panel, and on it you could push the face rings off from the backside of the plastic. I'm not sure about the metal one, though, however this is a great site-I'm sure lots will "chime in."
Old Nov 3, 2003 | 08:47 PM
barry's Avatar
barry
Have you looked at the back of the cluster? I'll bet you'll find some type of retainer on each guage and after you remove it, the whole guage will slide out. I wouldn't pry or try to pop it out until you've checked the back. You should be able to remove the screws on the dash and tilt the cluster towards you.
Barry
Old Nov 3, 2003 | 10:19 PM
daveengelson
Took the 2 wire connection nuts off on each gage and the housing comes off. The gage comes out thru the front of the panel.
Thanks Barry, I came so close to breaking out that darn screw driver.
Dave
