Sponsored by: Real Truck
6.0 VGT
Old Oct 22, 2021 | 07:05 AM
350xsx's Avatar
350xsx
Trailering
6.0 VGT
I have a 2006 F550 6.0 ZF6 all stock. I recently installed a new turbo due to wear/shaft play on the old functioning turbo. Worked better than ever. 300 miles later my VGT stopped functioning and i have practically no boost unless i rev it to the moon / am in 6th gear creating a lot of drive pressure.
i reinstalled old turbo thinking the possibility of failed new parts and have same results. Turbo was not stuck.
i have no boost leaks and no exhaust leaks.
i am getting accurate MAP, MAF, EBP, IAT readings
My EBP reading is high in reference to the desired value, i imagine due to the turbo being more of a blockage than anything at this point.
i am getting VGT readings between 80 and maybe 30 depending on load and rpm, i get these readings with the VGT plugged in or unplugged.
KOEO i am getting 11.5 volts to the VGT command wire and have 4 ohms of resistance between terminals on VGT actuator.
Any ideas? I feel as if ive been thorough and am running out of options
Old Oct 22, 2021 | 08:25 AM
350xsx's Avatar
350xsx
Trailering
Nevermind just swapped out a PCM with another and it ran fine. Have PCM ordered
thanks
FastTimes10
Mar 29, 2016 01:17 PM
blueoval4
Feb 21, 2016 06:56 PM
go6.0go
Feb 2, 2009 09:47 AM
woody1450
Aug 21, 2007 08:50 PM
achaffee
Jul 10, 2005 07:32 PM
