Wireless charging
Old Oct 21, 2021 | 10:54 PM
dlkay's Avatar
dlkay
Trailering
Wireless charging
Is wireless charging standard on 2022 Lariats? If so where exactly is it?
If not, am I better off just buying an aftermarket pad?
-Darrek
Old Oct 21, 2021 | 11:03 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Only standard on the Lariat Ultimate.
If you have that, the charge pad is in the front console compartment where the sliding lid covers it.
Old Oct 22, 2021 | 06:37 AM
Mlarv's Avatar
Mlarv
I will add that if it is like in my wife's 2020 Expedition, it is pretty much useless. If you have a larger phone than getting it in and out of it is a pain. The Qi charger is the older slower type that will not charge a newer phone at the fast charge rate. If you hit a big bump it may knock it off the charger so it is not charging.
I have an iPhone XR and have had these issue's (except the fast charge not available on the XR). I use the a cable to charge my phone and use Apple CarPlay.
I am getting a new iPhone 13 along with the Magsafe charger to see if it will work better in my truck. It sticks on the back of the phone and alingns itself to the charge ring.
Old Oct 22, 2021 | 07:06 AM
B-737's Avatar
B-737
I am getting a new iPhone 13 along with the Magsafe charger to see if it will work better in my truck. It sticks on the back of the phone and aligns itself to the charge ring.
same experience here w iphone 12.
I have read in places that its inherent to the iphone (12?) design, im curious how your 13 will do. I have not used my charging pad since trying it once.
Old Oct 22, 2021 | 07:12 AM
rhino_160's Avatar
rhino_160
Have to agree with all the above. My platinum has the wireless charger and my phone, although older XS Max, is a larger phone and it’s a pain to get in and out. It charges super slow as well.
the design, in my opinion, would had been fantastic if it had the wireless charger in the open storage area to the left of the cup holders and was a fast charger.
First world problems 🤦🏻‍♂️
But still absolutely love my '22 F350
Old Oct 22, 2021 | 08:18 AM
Mlarv's Avatar
Mlarv
The iPhone 12 and 13 are pretty much the same design. Without wireless CarPlay in our trucks wireless charging seems kind of stupid to me. I just plug in my phone when I hop in for a long drive and use CarPlay. On all the short trips I just drop it in the center tray or leave it in my pocket. I charge mine up every night, so it pretty much last all day.
I might try the MagSafe charger in the tray to see if it holds the phone and charges it without issues.
I am outa town again for a few weeks so it will be a few weeks before I can check it.
Old Oct 22, 2021 | 09:41 AM
SomethingRandom's Avatar
SomethingRandom
I’m still playing around with the built in charger, the issue I’m having is as the truck bumps down the road it lifts slightly and stops charging. I might just disable it all together via Forscan.
I just got these last night. I cut a hole in the rubber liner, and used some VHB tape to stick the charger to the plastic tray. 13 Pro Max in a Pelican MagSafe case fits well.
PIMCAR Center Console Organizer Compatible with Ford F150 2020 2019 2018 2017 2016 2015 Armrest Insert Accessories ABS Tray Pallet Storage Box Container (NOT for 2021 F150) https://smile.amazon.com/dp/B08YYWJH8Q
Anker Magnetic Wireless Charger,...
Amazon Amazon
The wireless charger needs a 20W feed. Plenty of cheap options. If you have an existing 12v -> USB C charger it more than likely will do the job. Charger comes with a USB C -> USB A adapter so you can use older chargers you might have as well.
Anker Car Charger, Mini Aluminum...
Amazon Amazon
Car Charger RAVPower 24W 4.8A Mini Dual USB Car Adapter with iSmart 2.0 Charging Tech for iPhone X / 8 / 7 / 6s / Plus, iPad Air / mini, Galaxy S8 / S
Amazon Amazon
i already had the ravpower and it seems to be working fine.
Old Oct 22, 2021 | 10:34 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Best, most reliable way to charge your phone is to just use the usb cable.
I personally have a high output fast charger cube plugged into the 110 outlet to charge my phone.
Old Oct 22, 2021 | 11:46 AM
dlkay's Avatar
dlkay
Trailering
Thanks for the info guys. I didn't know if was an "ultimate" only feature and wasted a bunch of time trying to figure that out.
Old Oct 22, 2021 | 01:07 PM
Texmudder's Avatar
Texmudder
The 13 fixed the issues that plagued the 12 with regards to Qi charging. My 12 was never able to charge using Qi and my 13 charges just fine. Since I have the Max, the OEM wireless charging location is completely worthless. I went with the console mount from ProClip found here: https://www.proclipusa.com/product/8...-console-mount. They have a few other options but blocking a vent is just not an option in Texas. On top of that base, I use their MagSafe holder: https://www.proclipusa.com/product/i...agsafe-charger.
Old Oct 22, 2021 | 01:10 PM
cat-alac's Avatar
cat-alac
It’s not a great design from factory, my Ip 13 fits but is difficult to get out and charge time is sloooow. usb still my preference
Old Oct 22, 2021 | 01:47 PM
powerboatr's Avatar
powerboatr
my wifes samsung a20 with the otterbox on...will not charge unless placed JUST right, until the next bump in the road then it stops...its a PITA. plugging in is best
so the spot now is a catchall for "stuff"
Old Oct 22, 2021 | 05:11 PM
Painted Horse's Avatar
Painted Horse
I use the USB-C charging cable. Lets me have Apple Carplay and charges much faster than the wireless.
The Wireless charger built into these trucks is first generation stuff and pretty slow compared to what the phones are capable of.
Old Oct 23, 2021 | 11:19 AM
Tsubakihara's Avatar
Tsubakihara
It’s possible I have low standards for electronics performance but my XS max and Samsung which is in an OtterBox both charge fine.
SCRWDRVR
2004 - 2008 F150
Jul 1, 2018 06:30 PM
draboo
Mar 24, 2018 02:16 PM
makuloco2000
2009 - 2014 F150
Mar 29, 2014 01:42 PM
GeneLaw1
Aug 15, 2012 03:50 PM
mmcrorey
Aug 4, 2003 03:20 PM
