94 Ford F150 Hazard Flasher problem
Old Nov 3, 2003 | 12:24 PM
mef's Avatar
mef
Unhappy 94 Ford F150 Hazard Flasher problem
My right front turn light is flashing (the dashboard indicator and the outside right front lite, but no other lights). The day before, I noticed the ABS light come on. Today the flasher is operating erratically. I pressed the hazard warning light button on top of the steering column several times and the flasher finally quit (don't ever recall pressing it to start this chain of events to begin with, but....). Press it again and only one light is flashing? Why would just one light flash and not the rest? I do not have a schematic. Everything else appears to be working properly (the ABS light even went out). Any ideas?
Old Nov 3, 2003 | 08:01 PM
Franklin2's Avatar
Franklin2
Sounds like the hazard switch is not working correctly seeing as it was hard to get operating correctly. I would turn it on and off a couple of times to see if it's engaging correctly, and wiggle it around to see if it affects the lights.
Old Nov 11, 2003 | 07:09 PM
noproblem's Avatar
noproblem
Your problem is most likly the multi function switch. It controls all the items you mentioned. I just had to replace mine because the headlights would just go out withput warning. Hazard lights are part of the multi function switch along with turn signals, headlights, and high beams.
96 F-150 XLT
HVACTOM
Feb 14, 2015 04:33 PM
will32_
24
Sep 28, 2014 10:18 PM
stownsen914
Apr 23, 2014 08:44 AM
naps1saps
Sep 4, 2012 01:21 PM
silverbullet99
1978 - 1996 Big Bronco
Jan 13, 2004 05:12 PM
