Front wheel well liner "filler" trim
#47
#48
Make sure you order the correct number of fasteners. I ordered (Fairway Ford) 2ea W712559-S900 & W708991-S439 expecting to receive 2ea packs of four (8 pieces of each part). Instead, I received these; two packages, clearly marked as packs of 4; cut open and only 2 pieces in each package. If I order more I'll get hit with another $12 shipping charge.
I have not installed them yet, so not sure exactly what I need.
#49
I’d read various reports of what was needed to install these. I emailed Fairway Ford and asked if the screw & clip part #’s were a 4-pk or single piece. They responded “single piece”. So seems they are doing like you say, opening the 4-pk bag and selling the parts individually.
I ordered all the parts for my install from FordParts.com.
see my post #19 in the thread below for pics & details of what is needed per the Ford parts diagram
https://www.ford-trucks.com/forums/1...r-liner-2.html
The following 2 users liked this post by number9xd:
#50
I’ll just post it here too……
So I found when I went to order these that the parts diagram shows each liner using 2 push pins (come with liner) and 2 screws (and clips). The screws and clips come in a 4-pack. Below is what I ordered. Just installed them per the parts diagram.
And here’s a pic on my truck.
The following 3 users liked this post by number9xd:
#51
The following users liked this post:
#53
#54
#55
This thread is about the "liner" that goes inside the bumper, below the wheel well liner. IMO these would work to prevent mud/muck getting behind the front bumper and leading to rust down the road. I think these are a good item to add no matter which version of wheel well liner you have.
#56
Installed the fender liner extensions last weekend after installing the front wheel well liners. I bought the clips and screws to use but ended up just using some of those plastic retainer pins that came with my trim removal tool. So far so good. If they decide not to hold I'll switch over to the clips and screws for those two holes. Cheap and easy install.
#58
#60
On the 17 you can see the two mounting points circled in red. Their are no provisions on my 24 for those mounting points.
Image from my 24. No mounting points on the backside of the bumper.
