Front wheel well liner "filler" trim
The following 3 users liked this post by 4wd6.7L:
I didn't have the right size for the plastic Christmas tree clips, and don't know the Ford part number for them.
I had leftover screws + speed nuts from Husky mud flaps, so used one of those on each side on the outer hole that was open. For the inner, I used a zip tie - at some point I'll locate properly sized Christmas tree clips and replace the zip ties.
Bob
Under related parts you will find the additional hardware. HM3(Part#: W708991) and HS2(Part#: W712559)
https://parts.ford.com/shop/en/us/bo...ller-6588815-1
The following 2 users liked this post by 4wd6.7L:
Bob
This is the one that I bought. It has some of the tools but there are plenty of other choices without tools if you just need the fasteners.
Bob
https://www.google.com/aclk?sa=L&ai=...gQIAhA-&adurl=
Bob
The following users liked this post:
FWIW, everything that these filler trim pieces attach to is painted steel - IIRC all part of the front bumper support.
The following 2 users liked this post by El Chupacabra:
Looks like...like I said, the Ford parts site generally only shows a partial part#. The clip for example, add -S439 to the end and you now have the complete part#. Follow the link I posted previously and compare the part# given for the actual trim piece compared to the part# in the first post.
W712559-S900 Fender Liner Screw
W708991-S439 Fender Liner U-Nut
These are sold by Ford in packs of 4. So you need 2 packs of 4 to have 8 screws and 8 U-nuts. From the OP it sounds like the filler trim comes with at least 2 but I went ahead and ordered 8 just in case I only get one or zero with my filler trim pieces LOL.
The following 2 users liked this post by nickshu:
#28
#29
Reference the front wheel well liner kit (HC3Z-16F099-A) and the filler parts (HC3Z16E206A and HC3Z-16E207A). I don't need the hardware kit for the liners themselves, just for the fillers?
Also, would there be any concern for being able to get to your front shocks with the full kit installed. I am on the fence about replacing my shocks. While the rear well liners look great and work well, I don't see any issues about trapping must and the like. Could the same be said for the front liner kit?
#30
