John Deere Plus 50 Oil
Old Oct 20, 2021 | 09:50 PM
Doug Savage's Avatar
Doug Savage
Anybody use this in their PS? I use it in my tractors, and I think it’s premium oil for sure - and it’s 15w - 40 weight.
Since I usually have it around by the gallons, just wondering.
Old Oct 20, 2021 | 10:48 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Check and see if it's on Ford's approved oil list.
I don't recall any JD oil on the list.
And, of course, 15w40 is only a warm weather oil.
Old Oct 20, 2021 | 10:52 PM
cpobst's Avatar
cpobst
No but I use Rotella in my John Deere! Looks like the JD oil is made by Chevron. It doesn't have the Ford standard on it but it is CK-4. Not much help I know.
Old Oct 21, 2021 | 12:00 AM
Doug Savage
So, for fall use a 30 weight?
Old Oct 21, 2021 | 06:20 AM
pig9r's Avatar
pig9r
You can run 5w40 or 10w30 year round in most all climates. Not sure if it would hurt anything but JD oil is not WSS-M2C171-F1. Here is Ford’s “approved” list. https://www.fcsdchemicalsandlubrican...SSM2C171F1.pdf
Old Oct 21, 2021 | 07:01 AM
Joe T's Avatar
Joe T
Run the 5/40 or 10/30 and stick with it unless you are towing heavy in warm climates.
Old Oct 21, 2021 | 07:02 AM
cpobst's Avatar
cpobst
Severe use like towing heavy Ford recommends 5w-40.
Old Oct 21, 2021 | 09:05 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
10w30 is what they come with from the factory.
I plan to run that year-round.
Old Oct 21, 2021 | 10:03 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
You would have zero issues running that oil.
Old Oct 23, 2021 | 11:57 AM
Tsubakihara's Avatar
Tsubakihara
Most likely true, but I would not recommend using something not approved to the fomoco oil spec.
Old Oct 24, 2021 | 10:31 AM
FishOnOne's Avatar
FishOnOne
I recall seeing a oil analysis on this oil and the zinc and phosphorous looked low in order to be both diesel and gas engine compatible and these type of oils are not approved by Ford. I wouldn't use it until you can confirm it has ~1k PPM of both zinc and phosphorous in order to be good for the PSD. For some reason Fords PSD upper valve train needs the extra phosphorous to prevent excellerated wear
white Buffalo
Mar 30, 2008 09:30 PM
Torstein
Oil & Lubrication
Aug 24, 2004 10:44 AM
03f150man
Oil & Lubrication
Apr 14, 2003 04:17 PM
CLAM_DIGGER
May 23, 2000 04:38 AM
