cat problems
Old Nov 3, 2003 | 11:48 AM
bill6302's Avatar
bill6302
Question cat problems
i might sound like an idiot, but does the 1992 f-150 5.8 efi have 1 or 2 cats. i bought the truck with it dualed out and i thought the 2nd muffler/cat was a muffler, but after reading in here i'm not so sure. any help would be apreciated
Old Nov 3, 2003 | 01:54 PM
WhëëlMå1's Avatar
WhëëlMå1
I am not sure if its the same as other models, but I believe there are two units on the Y pipe, correct? That is actually a two piece cat. It is a precat, and then the actual cat. They do the work of one single catalytic convertor.
Rich
Old Nov 3, 2003 | 02:06 PM
bill6302's Avatar
bill6302
ok. well i feel like an idiot, i replaced the 2nd cat with a 40 series flowmaster. would i get any better performance cutting out the muffler or the other cat? and if i cut out the 1st cat how would i connect the pipes as it is a dual inlet cat?
Old Nov 3, 2003 | 02:40 PM
WhëëlMå1's Avatar
WhëëlMå1
To get the best, legal horsepower, as well as keep future generations to come with cleaner air, you should run a high flow catalytic convertor. Is it true duals (from each engine bank back) or duals behind the muffler? Do you have youre check engine light on?
Rich
Old Nov 3, 2003 | 06:21 PM
bill6302's Avatar
bill6302
its duals behind the muffler and my check engine light isn't on
Old Nov 3, 2003 | 06:42 PM
akford351's Avatar
akford351
I'd just replace the front pre-cat with a Catco dual-inlet catalytic converter. Should cost you no more than $100.
Old Nov 3, 2003 | 08:15 PM
WhëëlMå1's Avatar
WhëëlMå1
Yup, Im with AKFORD351 on this one.
Rich
