Modular V10 (6.8l)
PO191 Engine Light on E450 Class C RV
Old Mar 9, 2025 | 12:26 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Originally Posted by BSO2012
Thank you for responding. I will follow your suggestions. Will let you know what happens. Thank you
Since this thread has been brought back to life, I'm curious @BSO2012: what happened with yours?
Old Mar 9, 2025 | 08:28 AM
Big Mama's Avatar
Big Mama
6th Gear
I’m getting the filter this week and will delete the code and look for any others and report back. I need to “unwinterize” it and fire up the generator too.
Old Mar 23, 2025 | 07:46 AM
Big Mama's Avatar
Big Mama
6th Gear
Yesterday I removed the dog house to look for loose or frayed wires a the FPS and watched live data using my OBD scanner. Moving the wires around did not change the psi. For the most part the psi stayed between 42 and 45 psi. Which sounds to me like the pump and filter are ok based on my research showing psi should be between 28-45. Is that right? I ordered a new FPS that’ll be here tomorrow. It’s an inexpensive part so I don’t mind swapping it out. What do y’all think?
Thanks in advance,
Steven
Old Mar 23, 2025 | 09:12 AM
QuiGonJohn's Avatar
QuiGonJohn
6th Gear
I don't know what nominal pressures should be. But it won't hurt to change the FPS.
Old Jul 9, 2025 | 07:21 PM
nigel1's Avatar
nigel1
1st Gear
Same 2005 E450 RV check engine light PO191
I changed the fuel rail pressure sensor, changed the fuel filter, put in a new fuel pump and fuel control module. Went for a drive and the RV was running great. Filled with gas and check engine is back on. Same PO191 code. What is wrong with these Ford E450s?!
Old Jul 9, 2025 | 08:21 PM
QuiGonJohn's Avatar
QuiGonJohn
6th Gear
Wow, I got a new Fuel Control Module, but never replaced it. And would only do the fuel pump as a last resort. So the last time I had gotten the code was in mid-May 2023, the morning we left out of Dickinson, ND. Heading W towards Belfield, RV went into passing gear on cruise and the light came on. Stopped in Belfield, my brother-in-law, who has a mechanic shop checked it all out, cleared the code. After we got home, I had a shop I trust check everything out and if they would have said the Fuel Pump needed to be replaced, I'd have done it. But they said it was fine. We drove it quite a bit over the next 2 years. But in early June 2025, driving in Oregon, between Klamath Falls and Bend, RV went into passing gear again, and I got the light. Had the code checked at Advance Auto in Bend, P-191 Code. I cleared the code myself. We drove the rest of our trip, ID, MT, ND, MN, IA, IL, KY, TN and back to FL, never got it again. It's just weird.
Vinford
Oct 2, 2021 02:18 PM
jcal1995
6.7L Power Stroke Diesel
27
Sep 30, 2021 02:22 PM
Amish Ford
Dec 7, 2018 11:07 PM
j_blueridge
2004 - 2008 F150
Nov 18, 2012 06:56 PM
