Another Wild Electrical Issue
Old Jul 16, 2022 | 05:32 PM
  #31
Towmeister's Avatar
Towmeister
My sincerest apologies for not following up sooner. The dealer's never figured it out. I used an OBD2 utility to reset the Battery Monitoring System (BMS) back in March and have not had a single issue since. I cannot believe the dealer never tried this over the past two years. I live in Florida and this think gets soaked regularly.
Old Jul 16, 2022 | 08:10 PM
  #32
realpsi's Avatar
realpsi
Trailering
Did you reset when the lights were not flashing? That is the issue I have is I can never get it to a place where the lights are not flashing.
Thanks for the reply. I tried resetting BCM and Battery Monitor, but I think it isn't really happening since I have no control over the ignition or accessory power.
As much as I hate it I think it is time for a flat bed ride to the dealership.
Old Jul 16, 2022 | 09:36 PM
  #33
Towmeister's Avatar
Towmeister
Pull both battery negative leads for ten minutes, should reset everything so you can get in there and do the reset. Will the truck start with the FOB?
Old Jul 17, 2022 | 02:02 PM
  #34
realpsi's Avatar
realpsi
Trailering
Thanks, I tried that. As soon as the truck has power it starts flashing and essentially locks me out of anything ignition related.
Old Jul 17, 2022 | 07:03 PM
  #35
morehouse7's Avatar
morehouse7
There was a thread recently where someone was sending off their BCM for an overhaul. There wouldn't be any need for programming I assume because it is already registered to your truck. It was a few hundred bucks I think.
Old Aug 4, 2022 | 02:04 PM
  #36
realpsi's Avatar
realpsi
Trailering
I want to followup and give the solution. Internal shorted BCM. BCM replaced all is well again.
lornedude
Escape & Escape Hybrid
May 16, 2021 08:44 PM
Worm79
Apr 1, 2020 11:11 AM
saskowner
Jan 16, 2019 04:38 PM
Jake321
Jun 16, 2013 04:00 PM
MikeA-F250
Apr 12, 2003 08:23 AM
