Right rear brake dragging!!
Old Oct 16, 2021 | 06:06 PM
andy33040's Avatar
andy33040
I have a 2005 f350 DRW cab & chassis
I just taken back this truck from my now non existing crew and god knows what they have done to it ?
probably some drunken dukes of hazard shenanigans?!!
just can’t get this brake not too drag
new caliper Napa
new rotors / old ones where extremely worn on one side
new inner and outer wheel bearings / took Napa four times to get right ones so I have taken it apart three times or more lost track
new brake pads/ Napa sold me wrong ones three times / second attempt I tried putting on wrong pads I couldn’t get caliper on so kind of messed up ring on piston on caliper!!
See it on the top piston
okay so I notice some wobble on wheel during one of my many times working on truck and started thinking maybe it was a bent axel? Remember I thought my crew was doing stupid drunk stuff with truck ! I took it to local shop and they concurred it was axel now new axel still grinding !
new brake lines both sides all the way over to center connection I had help this day and got a good bleed on brakes had trouble with right side but eventually it starting squirting good when open still grinding !
in desperation and frustration and my remaining helper advice which he claims he was a BMW technician I took the parking brake completely out just in case that was the problem which it wasn’t!
I did re-grease slid pins and it’s still grinding!
Actually sounds worse
I forgot but I also did the differential oil which I probably need more since I take axel out every other week!
any help or guidance would be greatly appreciated
have a great weekend
andy
Old Oct 23, 2021 | 11:40 AM
six_eaux's Avatar
six_eaux
That tear on the top piston in your picture could be the root cause of your dragging issue. Water intrusion which leads to rust and it gets in a bind when attempting to retract. It also looks as if you have a deformity on the piston (hammer or pry bar) from opening up to make room for fresh pads. With a mark like that, that piston may so be cracked. Look at it under a bright light. If it were mine, I would rebuild or replace that caliper assembly.
Old Nov 3, 2021 | 04:28 PM
andy33040's Avatar
andy33040
Thanks for the help the brake is fine pretty sure at this point it’s the differential side carrier bearing
pulled axel out and no noise !
now need figure if I want do it myself or just get a whole rebuilt differential?
thanks again sorry for late response just couldn’t log on here been working 18 days straight and totally exhausted
Old Nov 4, 2021 | 12:00 AM
Fuzzpuss's Avatar
Fuzzpuss
What does a carrier bearing have to do with a dragging brake caliper?
Old Nov 4, 2021 | 03:22 PM
andy33040's Avatar
andy33040
The differential carrier bearing not the driveline carrier bearing just sounded like the brakes dragging
Old Nov 4, 2021 | 07:02 PM
Fuzzpuss's Avatar
Fuzzpuss
That's funny because the driveshaft carrier bearing on my new truck sounded like a rear brake dragging.
That must have been a bad differential carrier bearing. I hope you're rebuilding the rear end.
Old Nov 5, 2021 | 08:17 AM
andy33040's Avatar
andy33040
I did check the driveshaft carrier bearing actually put phone on frame and did a video while driving!
not it
might be just buying a whole new rebuilt rear end
I live in the keys and don’t have many choices on shops who specializes in this kind work and am super busy with work
the truck went through saltwater during hurricane Irma helping people out and clearing roads out
Damn storm still effecting me
Elanham59
Sep 27, 2021 06:20 AM
BlackTruckDave
Oct 19, 2016 12:23 PM
Codyaye
Feb 25, 2016 01:50 PM
t_dub
May 1, 2014 05:27 AM
quarterhorsemom
Oct 22, 2005 08:19 PM
