Ground point in kick panel
Old Oct 16, 2021 | 02:28 PM
llblake64's Avatar
llblake64
I did a quick search but couldn't find any real answers.
I'm wiring my dashcam to the upfitter switches but can't find any obvious ground points in the passenger side kick panel area. The only "solution" I found in doing a search was someone who had used another one of the 4 pass-through wires to create a ground connection back under the hood. What other solutions are there, or where should I be looking for a ground point?
Old Oct 16, 2021 | 02:51 PM
4wd6.7L's Avatar
4wd6.7L
There is a large ground lug behind the passenger kick panel. Here is a picture of it (left of the yellow mark).
I originally was interested in a ground location on the drivers side but couldn't find any info on one, so I went passenger side.
Old Oct 16, 2021 | 03:59 PM
llblake64's Avatar
llblake64
I did notice that one with the tab, and it may have had a green mark to the left of it. Looks like I may need to take off that other trim panel to easily access it. Thanks for the help!
Old Oct 16, 2021 | 04:03 PM
4wd6.7L's Avatar
4wd6.7L
When removing the kick panel the sill plate will have to come out and the weatherstripping moved. If you don't move the weatherstrip the kick panel can't come off straight and can break the plastic dowl off. I made that mistake. Doesn't really matter but can be avoided.
Old Oct 16, 2021 | 04:05 PM
llblake64's Avatar
llblake64
Thanks for the warning!
Old Oct 16, 2021 | 05:22 PM
cficare's Avatar
cficare
On my 2017 KR, there was another stud I used for a ground which was much easier to access than the one shown above. It was just forward if not under the leading edge of the carpet on the right side of the passenger footwell ... close to the fuse panel.
Old Oct 16, 2021 | 05:27 PM
(Overthebars)'s Avatar
(Overthebars)
Following..
Old Oct 16, 2021 | 05:32 PM
4wd6.7L's Avatar
4wd6.7L
Possibly this one?
Old Oct 16, 2021 | 05:37 PM
cficare's Avatar
cficare
Possibly this one?
I believe that's it. It's where I located the ground for my dashcam.
Old Oct 16, 2021 | 05:43 PM
KU4OJ's Avatar
KU4OJ
I had my dash cam installed at Best Buy. Their installers are reluctant to mess with those factory ground points, so they drilled a small hole in the bracket (see near top of photo, with the bolt and 2 slots in it) and ran a sheet metal screw into that. A ring terminal on the ground wire completed the connection. I think they said those connections sometimes strip out. It works and the solution suited me.
Old Oct 16, 2021 | 06:11 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by KU4OJ
... so they drilled a small hole in the bracket (see near top of photo, with the bolt and 2 slots in it) and ran a sheet metal screw into that. A ring terminal on the ground wire completed the connection.
Pretty sure I've seen a pic somewhere on this forum using that bolt/bracket, as is, as a ground location.
Old Oct 17, 2021 | 07:02 AM
jade97's Avatar
jade97
I used a nut, bolt and ring terminal on an existing dash bracket by the glove box.
Old Oct 17, 2021 | 07:50 AM
llblake64's Avatar
llblake64
Thanks for the other suggestions, I'll be finishing up the install today.
Old Oct 17, 2021 | 11:13 AM
DSLTRK60's Avatar
DSLTRK60
What dashcam did you end up with and what led you to choose that one? I'm running a Vantrue now but always looking for another viable option.
Old Oct 17, 2021 | 06:02 PM
Marcm15's Avatar
Marcm15
I made this mistake!!!
