5.0 TPS code 122 intermittant
Old Oct 15, 2021 | 06:29 PM
spurredon's Avatar
spurredon
When my TPS was going bad it was intermittent as well. No CEL and it ran so-so, then the CEL would suddenly come on and it would run and shift worse.
I am not a big fan of piercing to test wires. I went to the junk yard and got the connection point for the TPS with about 4 inches of wire on either side. You can un plug it and then plug your existing TPS into the junkyard connector and then plug the junkyard TPS connector into your harness. This leaves you with three pairs of wires to twist together and that is where you can take you readings. It seems like a bit of messing around but once you have this little gem you will be happy. Nice place to attach clips for taking readings.
Old Oct 15, 2021 | 08:36 PM
yonu's Avatar
yonu
I actually was debating on doing that f the problem kept happening to make my life easier.
Old Oct 15, 2021 | 08:50 PM
Hit Man X's Avatar
Hit Man X
Same thing I do for my rides or make some jumper wires between it.
Old Oct 16, 2021 | 12:08 AM
Scndsin's Avatar
Scndsin
This is mine:
Old Oct 16, 2021 | 07:04 PM
spurredon's Avatar
spurredon
Originally Posted by Scndsin
This is mine:
That is it, soldering really makes a difference too.
sandymane
Feb 4, 2021 10:17 PM
Slip ford man
Jul 31, 2011 01:37 PM
96Bronco1
1978 - 1996 Big Bronco
May 12, 2010 05:37 AM
jzman7
Aug 12, 2007 03:38 PM
aberfoyle
1983 - 2012 Ranger & B-Series
Aug 26, 2004 10:49 AM
