Why buy a F250 when a F350 cost only a little more
OK, so I'm in the market for a Ford Super Duty truck. I see so many more F250 trucks than F350. I always thought it was the price difference but I just realized that there isn't much difference (couple thousand). So I've trying to understand why do some many people opt for the F250. I'd figured a couple thousand more for payload you may never use is still worth it.
The Powerstroke F250 with HCTTP is identical to Powerstroke F350 from 2020-present. In some states F350 is taxed and licensed as a commercial vehicle at higher cost which is why Ford offers this. The sticker on the F250 HCTTP will show lower hitch weight rating but the parts are all identical. Many threads discussing this around here.
I bought a 250. My 250 Tremor is literally identical in every respect to a 350 Tremor that's equipped the same way except for one letter in the VIN#. It was a little less expensive and the actual resell could be a little better because the 3/4 ton market is larger than the 1 ton market......at least in my area. I'll never max out payload or tow capacity.
The following users liked this post:
My F250 is identical to a 350 except for the badging, and of course the “listed” payload. But even with a 3016 payload rating with the 6.7, it’s more than I need. Besides, knowing that my truck is the same as a 350 it wouldn’t hurt my feelings even if I did need to go over the payload by a few hundred lbs. besides this, it was less expensive than a 350 and insurance is less. In some states the licensing and registration is less too.
Buy what you need.
Buy what you need.
The following 2 users liked this post by ATC_F350:
