Sponsored by: Real Truck
Drivers side CV shaft
Old Oct 13, 2021 | 10:28 AM
Aknfreighter's Avatar
Aknfreighter
Hi all,
Just bought a 2004 F250 4X4. In the recommended maintenance schedule it states to replace the drivers side axle cv shaft.
Any particular reason for that, and if so, why not passenger side?
Thanks, Steve
Old Oct 13, 2021 | 10:38 AM
Super Duty DJ's Avatar
Super Duty DJ
Since your truck has a solid front axle, there are no CV shafts. You have front and rear axle shafts (with replaceable ujoints on the front shafts) and front and rear driveshafts with replaceable ujoints, so there should be no need to replace shafts unless you have damage to the shaft itself. I am curious, where did you get this maintenance schedule from?
Old Oct 13, 2021 | 11:03 AM
Aknfreighter
You are correct. I just wasn't thinking it through that I do not have cv shafts.
This is where I got the info; https://www.yourmechanic.com/schedul...mileage=150000
Old Oct 13, 2021 | 12:15 PM
Super Duty DJ
I would recommend that you go here on the Ford website and download the appropriate Owner's Manual and use the maintenance schedule from that to avoid weird recommendations from third party sites.
https://www.ford.com/support/owner-m...header-support
greentree ford
Mar 4, 2013 05:00 PM
cabloom300
Apr 30, 2010 03:33 PM
dumontkid
Feb 11, 2009 04:06 PM
Taasman
Apr 24, 2004 04:43 PM
