Electrical System Problem
Old Nov 3, 2003 | 07:04 AM
mef's Avatar
mef
Question Electrical System Problem
1994 Ford F150 - My right front turn light is flashing. With the ignition on or off and the turn signal lever in the neutral position (although it makes no difference what position it is in). I pulled the turn signal fuse - no luck. I pulled the round flasher relay - no luck. I finally pulled the fuse for the flasher - it turned off. If I put the fuse back in it starts flashing again. I have to pull the fuse to keep from draining the battery. With this fuse out, my turn signals do not work either. I do not have a schematic. Any ideas?
Old Nov 8, 2003 | 12:46 AM
Greasemonkeyjoe's Avatar
Greasemonkeyjoe
Check the 4 way flasher switch...they are prone to sticking
