I preparing for the V/modded B spring swap and I'm having a very hard time used ford springs in good shape. I'm shopping around for other viable options for new springs. I've read a lot of older posts and found that when talking to aftermarket spring shops it better to reference the factory spring capacity rather than the Ford code. I found that the front V codes have a 5200 lb capacity (per pari) but I can't seem to find the factory capacity rating for the ford B code rear spring anywhere.
ATS suspension is one option I was looking at for springs. if I go for a 2600 lb rated front spring it is actually listed as the X code on their site.
I'm wanted to to the same thing for the rears (ensure I'm using the spring ratings not the ford codes).
BTW has anyone performed the V/modded B swap using springs from ATS or anywhere else?
Thanks.
