Rear B code Capacity???
Old Oct 12, 2021 | 12:53 PM
Chupp's Avatar
Chupp
I preparing for the V/modded B spring swap and I'm having a very hard time used ford springs in good shape. I'm shopping around for other viable options for new springs. I've read a lot of older posts and found that when talking to aftermarket spring shops it better to reference the factory spring capacity rather than the Ford code. I found that the front V codes have a 5200 lb capacity (per pari) but I can't seem to find the factory capacity rating for the ford B code rear spring anywhere.
ATS suspension is one option I was looking at for springs. if I go for a 2600 lb rated front spring it is actually listed as the X code on their site.
I'm wanted to to the same thing for the rears (ensure I'm using the spring ratings not the ford codes).
BTW has anyone performed the V/modded B swap using springs from ATS or anywhere else?
Thanks.
Old Oct 12, 2021 | 09:02 PM
pirate4x4_camo's Avatar
pirate4x4_camo
your stock springs
front
v8 330 lbs/in
v10 350 lbs/in
7.3 370 lbs/in
rear 420 lbs/in
the rear f250 B code is a 2 stage spring so there are 2 rates
primary 330 lbs/in
secondary 660 lbs/in
depending on how you modify the B pack will determine the final rates but most of the ones I see are
primary 420 lbs /inch
secondary 660 lbs/inch
spring capacity is a simply Travel x rate = capacity
Jesse73iditurbo
Apr 1, 2021 10:32 AM
AllaboutMPG
20
Jun 7, 2015 01:47 PM
wrxin
May 30, 2014 09:09 PM
F2502011
6.7L Power Stroke Diesel
Nov 19, 2013 02:37 AM
420CREW
Feb 20, 2010 06:29 AM
