Modular V10 (6.8l)
2016 F-550 Surging Issue
Old Oct 11, 2021 | 08:18 PM
Fifty5D's Avatar
Fifty5D
My truck has an issue where under any sort of acceleration it surges horribly, sometime to the point where my head is bouncing off of the headrest. Occasionally I will get bank 1 and 2 fuel ratio imbalance codes that randomly go off. Here is a list of everything that has been replaced so far:
  • MAF (2 times)
  • Upstream and Downstream sensors
  • Air filter
  • Fuel pump
  • Throttle body
  • Intake
  • Engine (2 years ago)
I think that's all
My truck has a ton of added weight to it due to my job, any ideas?
Old Oct 12, 2021 | 12:18 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
If you don't have one already, get some kind of Bluetooth OBD-II adapter and start reading things - like fuel pressure for starters.
Others here will chime in...
Oh, and WELCOME to FTE!
Old Oct 12, 2021 | 04:52 PM
bajaphile's Avatar
bajaphile
Is the surging coming from the engine or the transmission?
If you've changed all the above, it sounds like a classic faulty TPS (throttle position sensor) or could be a fuel delivery issue, most likely a clogged filter if you've already done the pump. First step would be to get an OBDII scanner to read codes pull some live data, especially when the vehicle starts surging.
Google ForScan and get a cheap bluetooth OBDII adapter for it.
Bill1369
Aug 21, 2019 10:14 AM
silentdub
2004 - 2008 F150
13
Jan 24, 2019 06:55 PM
quick35th
Dec 26, 2011 04:40 PM
Fordzilla80
1997 - 2003 F150
May 19, 2010 08:52 AM
Roland Donnell
Texas Chapter
Nov 16, 2004 11:08 AM
