OBS P0RN?
Old Nov 2, 2021 | 05:18 PM
  #31
96 OBS's Avatar
96 OBS
Figured I’d throw the ol girl in here too
When I got here^^
and when I left her
Old Nov 2, 2021 | 05:19 PM
  #32
96 OBS's Avatar
96 OBS
Got a lot of hate for the semi mirrors but I still think they fit the truck
Old Nov 2, 2021 | 08:45 PM
  #33
oldbird1965's Avatar
oldbird1965
I still have my first one, still runs good. Second one burned up. This is my first one:
Old Nov 2, 2021 | 08:46 PM
  #34
96 OBS's Avatar
96 OBS
you got that and the ox? Didn’t know you had two!
Old Nov 2, 2021 | 09:07 PM
  #35
Hit Man X's Avatar
Hit Man X
Sweeeeeet. A Tracker! My pal has two Metros both early ones
Old Nov 2, 2021 | 09:29 PM
  #36
oldbird1965
The 'mule' got retired and I only use it to haul water when I'm in SD at our old place. I only put about a thousand miles on it a year and so far it still runs good. When I got the newer 'Mobile Suites' I needed a dually because it has 5K tongue weight
I've had that little Tracker for about ten years now. I used to haul it behind the 5er but after a couple of years of that I quit. I was to nervous being 65 foot long. If you look close in my signature you can see it behind my 5er. Tow it four down and the owners manual says to put the five speed in 2nd gear and the transfer case in neutral, I still am confused about that.
Old Nov 2, 2021 | 10:04 PM
  #37
97-psd's Avatar
97-psd
Ya know, I think we used to have a pic thread. I need to see if I can find it and bump it back up.
Old Nov 2, 2021 | 10:12 PM
  #38
97-psd's Avatar
97-psd
Found it. Should be on the first page again
Old Nov 3, 2021 | 12:31 PM
  #39
fordman67's Avatar
fordman67
The ol' ***** box doing the thang
Old Nov 3, 2021 | 12:41 PM
  #40
fordman67's Avatar
fordman67
man...wish I had any of those back...now all I have is junk and parts
The blue or bronco I seriously should NOT have sold...#lyfefail
Old Nov 5, 2021 | 03:16 PM
  #41
wkf94025's Avatar
wkf94025
I don't usually do my photo shoots at the dump, and I had other guys waiting in line to dump after I cleared out, but couldn't resist taking this one. Never knew how much I would love my OBS, or my dump trailer...
Old Nov 8, 2021 | 05:13 PM
  #42
JCart's Avatar
JCart
Current pet, 97 with Dana 60, PMF RSK, FFD205/30s Hydra with Jelibuilt files, IC, E-fuel, KC internals, with 1.0 A/R turbo, tossed the E4OD for ZF-5, 211,000 kms. Cheers
Old Nov 8, 2021 | 05:20 PM
  #43
JCart's Avatar
JCart
Other pet came as a 4x2 with 51,000 kms. Now has 225ish swapped in a D60, with Sky RSK, ZF-5, 3:55 gears Hydra with Jelibuilt tunes, E fuel needs to be plumbed into back of heads, planning for an IC and have some 175/80 injectors (to install) just for fun. Just love these old trucks… Cheers.
Old Nov 9, 2021 | 01:13 PM
  #44
wkf94025's Avatar
wkf94025
@JCart seems like you're fairly facile with the axle/tranny swaps!
Old Nov 9, 2021 | 05:19 PM
  #45
JCart's Avatar
JCart
wkf94025, factile... heh had to look that up! More the case of fumbling around and having it work out, these are basically bolt together mods, in part why I love these old body style trucks. Mine all have been dependable, predictable trucks, also helps some if you keep them for a while and get to learn them and the weak points. Sites such as this one, PSN, PSA with helpful fellas have made the mods and maintenance pretty straight forward. Also should mention a host of vendors that help to modernize, add power to these rigs is incredible really.
