Tech Test
Old Oct 11, 2021 | 09:06 AM
429poweredf350's Avatar
429poweredf350
Tech Test
OK, I have a test for all you techs out there. Have a unique situation and hope one of you can help me. Found a couple of chaffed wires on my engine harness so decided to remove the main engine harness and go through it. Basically just visually inspected the wires, replaced a couple pigtails (turbo and ebp), and retaped the harness. Reinstalled the harness and truck started right up and gave me the following codes. All referencing low voltage or reading.
P0107
P0237
P0405
P2104
P2132
P2138
P2139
P2285
I rechecked and don't think I forgot to plug anything back in. In the vast knowledge of your brain housing groups can you think of anything common to all of these codes or give me some direction? I sure would appreciate it.
Thank you
Old Oct 11, 2021 | 10:35 AM
TooManyToys.'s Avatar
TooManyToys.
P0107 MAP low input open VREF, signal circuit short to ground
P0237 MAP sensor circuit open, short to ground
P0405 EGR sensor circuit low or short to ground
P2104 TSP failure
P2132 TPS sensor circuit low, open signal circuit short to ground
P2138 TPS sensor circuit low, open signal circuit short to ground
P2139 TPS sensor circuit low, open signal circuit short to ground
P2285 ICP sensor circuit low, open signal circuit short to ground
The visual inspection was not enough. You need to check continuity pin to pin as well as short to shield and short to other wires. I don't have an '06 layout. I haven't checked if there is any difference between '03 and '04.
Old Oct 11, 2021 | 05:16 PM
Yahiko's Avatar
Yahiko
Jack I will upload that as soon as I get home.
Old Oct 11, 2021 | 09:51 PM
87crewdually's Avatar
87crewdually
I'd first start with clearing the codes and see what comes back. They may be old stored codes from previous.
Old Oct 11, 2021 | 11:54 PM
Yahiko's Avatar
Yahiko
This should give you a sleepless night reading.
File Type: pdf
File Type: pdf
Old Oct 17, 2021 | 09:15 AM
429poweredf350
Thanks for the replies guys. cleared the codes and same ones came back. Had none of these prior to removing the harness. Was hoping someone had enough knowledge that they would know what's common to all these things and give me some direction on where to look.
Old Oct 17, 2021 | 11:01 AM
TooManyToys.
Ahhhh, a short in the wiring.....
Either replace the harness or test it all out like a good tech would do. You are not going to get "look 6 inches up from the EGR connection, 2 inches from the oil temp sensor, blue with a white stripe".
Old Oct 17, 2021 | 11:11 AM
Don Naslund's Avatar
Don Naslund
Are you sure that the ground wire is good on the left side at the FICM?
Old Oct 17, 2021 | 12:03 PM
TooManyToys.
Shielding ground. Not a bad thought, but I don't think it's that.
Old Oct 17, 2021 | 12:32 PM
87crewdually
Did you have all the codes first, then you removed harness and found chafes and replaced pigtails plugs?
Or did you find chafes, removed harness & replaced plugs/pigtails and now you have all these codes?
I ask because maybe you wired a pigtail wrong and now have a short. Maybe start unplugging one sensor at a time and clear the codes and see what comes back.
If for example you unplug the EBP sensor and codes don't come back (except an EBP open code) then you'll be closer to the problem.
Old Oct 18, 2021 | 10:16 PM
429poweredf350
I wanted to thank everyone for their input. The ground wire was loose behind the FICM but not my problem. Disconnected the sensors one at a time that I replaced the pigtails on. EBP was the culprit. Disconnected it and all codes went away but that one. I will check the wiring tomorrow. This is a great forum with a great group of guys and a lot of knowledge. Thanks again.
Old Oct 18, 2021 | 10:19 PM
87crewdually
Awesome. Glad you got to the bottom of it. Let us know how it all works out.
Old Oct 19, 2021 | 12:23 AM
Yahiko's Avatar
Yahiko
The diagram for the 2006 year.
Old Oct 19, 2021 | 07:22 AM
TooManyToys.
Man, you totally nailed that Pete, to the sensor.
Old Oct 19, 2021 | 09:32 AM
87crewdually
Thanks Jack.
Hows that saying go, Even a blind squirrel finds a nut once in awhile!
Or, I should of been a roofer, I nailed it! 🤣
Does this mean I passed the test? I guess we have to wait and see.
Ok I'm done now.
