Hey all, my living quarters horse trailer has a GVWR of 15k. I had super heavy duty tires put on it the day it was new couple years ago. The tires that came with it were factory junk basically. The new tires say 110psi cold on the side wall. The shop that did my bearings few months ago I just noticed put them at 80. I’ve noticed they are a little warmer to the touch than I like so I bumped them up to 100psi just now. Haven’t used trailer yet to compare. Should I just bump them up to the rated 110? I was told to always go just under max. Thanks !
Just a general answer: if your trailer is anywhere near gross weight then 100lbs sounds about right....Next time you tow it with the new pressure test it again for heat under the same driving cycle that should tell you something especially if it's running a little cooler...
The stiffer setting may also change the trailers handling as well....Again take note as I suspect it may have less side play & is gripping the road more ??
110 PSI is probably the maximum allowed inflation when cold. There is a chart available that lists standard air pressure based on tire type, size, axle rating and GVWR.
Another consideration is the wheel or rim. Not all rims are created equal and not all rims are capable of safely holding 110 PSI.
Don't listen to some guy on the internet when you are looking into your safety. Check for yourself and be confident about your choices.
Most tire manufacturers have a chart of inflation pressure versus weight on tire.
From what we know so far of your situation, you have a 15K trailer and good tires that you've swapped onto it.
Is it a 15K GVW on three axles or two (or four or etc.)?
What load rating do the new tires have?
What size are the tires?
What are the rims rated for?
Are the current tires radial or bias ply?
What were the previous tires rated for?
What were the previous tires' size?
I ask all of this because, for example, many motorhomes and trailers have a certain size tires and a specification for inflation pressure that is lower than the sidewall pressure. Overinflating will make them ride horribly and shake themselves to pieces.
When you changed the tires to what are most likely a "G" rated tire, did you also change the rims, or did you check that the original rims are rated for the higher pressure. I would expect a reputable tire shop would have checked the rims. If the rims are rated for 110 psi, you can inflate the tires to that pressure. However, if the rims are only rated for 80 psi and you inflate the tires higher, you are using the factor of safety built into SWL's.
Our 5'er scales about 16,500 lbs, with 12,500 to 13,000 lbs on the axles. I currently use 16" "G" rated tires and normally run pressures of 100 to 104 psi. My rims and tires are rated for 110 psi.
Your bearings were changed. That potentially changes heat generated by bearing. If tire pressure was constant in past along with load, I would suggest temperature change has more to do with bearing change than having to do with tires. Tire pressure should reflect load and wheel rating. My two cents,
