DRL ??
Old Oct 8, 2021 | 12:23 PM
sgthawkusmc's Avatar
sgthawkusmc
Originally Posted by helifixer
it is drl, when the truck is in drive the low beam head lights are on and no tail / marker lights are on. when the day light gets low the tail / marker lights come on
Auto headlights is not DRL and DRL is not auto headlights. Auto headlights turn your head lights on when dark and shut them off when it's light. DRL are Daytime Running Lights. Yes, the DRL can work in conjunction with auto headlights, but it is not auto headlights. If you disable the DRL, it does not disable the auto headlight.
Old Oct 8, 2021 | 12:29 PM
JHForman812's Avatar
JHForman812
unless my 22 is programmed different, none of my headlights are on when DRL is on, the high beam and low beam lights are off. The DRL is only the halo.
Old Oct 8, 2021 | 12:50 PM
JHForman812
Factory DRL
forscan mod to use parking lights with DRL
it’s hard to see but the roof lights and mirror markers are also on
Old Oct 8, 2021 | 12:56 PM
sgthawkusmc
Originally Posted by JHForman812
Factory DRL
Sharp truck!
Old Oct 8, 2021 | 12:58 PM
JHForman812
Originally Posted by sgthawkusmc
Sharp truck!
thank you!
Old Oct 8, 2021 | 01:58 PM
mcmurm's Avatar
mcmurm
Do you have the forscan setting for this? I looked in the spreadsheet but didn't see it.
Old Oct 8, 2021 | 02:02 PM
JHForman812
BCM 726-38-01 xxxx xxxx 01--
thank @livinItup for the code!
Old Oct 8, 2021 | 02:03 PM
mcmurm's Avatar
mcmurm
Awesome. Thanks guys.
Old Nov 12, 2023 | 01:52 PM
spmbmt's Avatar
spmbmt
2nd Gear
I don't understand why people don't just turn on their headlights if they want drls... I guess it's the whole lazy do it for me automatically culture thing now. Make me safe...
Calm down there, skippy. No one is trying to take your rights. Some people like them on the new trucks just because the LED bar looks cool in the day time. They are much nicer on the Lariat than on the King Ranch for some reason.
Old Nov 12, 2023 | 02:25 PM
Qvan666's Avatar
Qvan666
Originally Posted by Poncho450
My guess would be that Uncle Sugar mandates the DRL option and that laziness doesn't have a whole lot to do with it.
Not so much Uncle Sugar (USA), not required in the USA but they are required in Canada (Aunt Beaver???) and a few other countries where Super Duties are exported to so I imagine the Ford Engineers made it easier by having them there but with the ability to turn off. My 08 350 was a Canadian truck and it had DRL activated. I had the dealer turn them off when I bought it in the US.
bob
Old Nov 13, 2023 | 07:28 AM
pdumpbody's Avatar
pdumpbody
Nothing was said about rights being taken. But thanks for the complimentary heads up about how that's absolutely not the case.
Old Nov 13, 2023 | 07:34 AM
pdumpbody's Avatar
pdumpbody
I know it's there but I never liked the auto setting. For whatever reason, when it comes to exterior lighting on the vehicle, I go for the certainty of an on-off switch.
Old Nov 13, 2023 | 07:50 AM
  #28
Poncho450's Avatar
Poncho450
I used to not really care about DRL so much. But since I once got into FORScan and somehow managed to get the fogs to come on with DRL, I kinda like it. Mostly because I have yellow fogs that contrast nicely with the white headlights and white switchback front turns that are also on with DRL. I think it makes for being more easily seen.
But others might not care for DRL and that's just fine too. Most everyone personalizes their vehicles to some extent.
Old Nov 13, 2023 | 11:02 AM
  #29
4wd6.7L's Avatar
4wd6.7L
I use the auto setting pretty much only for the DRL lights (daytime), which on mine are just the outer LED's, and only when I want them to be on. I do think more cars/trucks should have an auto setting for the dummies I see every night driving around with just the DRL's on.
One thing I hate, that could be related to auto headlights, are cars that are parked in parking lots with their lights blaring at the car parked facing them. I assume they are so used to auto headlights that they are clueless how to manually turn the headlights off.
Old Nov 13, 2023 | 12:40 PM
  #30
BC2019F250's Avatar
BC2019F250
I think the bigger issue about night driving with DRL's on came when the dash lights started coming on when you start the vehicle. People see the dash light and think the headlights are on. In the old days you had to turn the headlights on to be able to see anything on the dash.
