Y-Block Intake manifold Install Question
Old Oct 7, 2021 | 12:29 PM
FirstF100's Avatar
FirstF100
I'm planning on replacing my intake manifold on my 292 y-block tomorrow. Is it necessary to use RTV silicon on the intake gasket, or will a new Fel-pro gasket seal just fine without using silicone? I tried searching YouTube but there so little info out there about Y-blocks. Thanks.
Old Oct 7, 2021 | 01:28 PM
pintoplumber's Avatar
pintoplumber
I smear the silver colored neversieze on both sides of the gasket. Works good for me. Currently I have a 239 gasket glued to the 272/292 gasket and coated with the neversieze. The Edelbrock FM 354 tripower has smaller ports than my heads. No leakage problems.
Old Oct 7, 2021 | 04:41 PM
abe's Avatar
abe
I think I used the copper gasket spray on the gasket.
Old Oct 7, 2021 | 08:00 PM
FirstF100's Avatar
FirstF100
Okay thanks. When I pull the current manifold off, there was a bunch of silicone used. I’m not a big fan of using it unless it’s a must.
Old Oct 8, 2021 | 02:24 AM
Dirk N's Avatar
Dirk N
1956 Ford truck shop manual
The shop manual does not mentioned any sealer. For example water pump housing it does. But using sealer at the water passage is always not a bad idea.
Old Oct 8, 2021 | 03:18 PM
jerryst's Avatar
jerryst
I just put on a little bit of windshield gasket glue. I call it gorilla snot.Just enough to stay in place.
Thanks
Jerry
Old Oct 11, 2021 | 11:32 AM
FirstF100's Avatar
FirstF100
Okay, so what’s the trick to getting the thermostat housing not to leak?
Old Oct 11, 2021 | 03:23 PM
jerryst's Avatar
jerryst
rtv or I use same windshield glue.
Jerry
joe7865
Sep 22, 2018 09:58 PM
Warren1974
Aerostar
Oct 30, 2009 07:32 PM
joe blow
Mar 25, 2009 05:15 PM
asmith6
Nov 30, 2007 09:35 PM
ggadwa
Apr 24, 2006 09:57 AM
