Steering wobble
Old Oct 7, 2021 | 09:08 AM
Gozlin's Avatar
Gozlin
Steering wobble
So I have a 2019 F450. I put a 2.5" leveling kit on the front with a dual Bilstein steering stabilizer. I have the slightest wobble that is causing uneven wear on my front tires. I have been told this is unavoidable, but I find this hard to believe. Should I add more stabilizers? Is there something else I can do?
Old Oct 7, 2021 | 09:31 AM
MAX4utah's Avatar
MAX4utah
This is a good video explaining
Old Oct 7, 2021 | 01:14 PM
Louisville Joe's Avatar
Louisville Joe
Exactly. Steering stabilizers will not 'fix' a loose front end, they might cover it up if it isn't too bad.
Old Oct 7, 2021 | 01:55 PM
morehouse7's Avatar
morehouse7
Did you add more degrees of caster by changing out the caster shims when you lifted it?
Old Oct 7, 2021 | 09:07 PM
bent-1's Avatar
bent-1
There is a TSB on caster changes to address wobble.
Old Oct 7, 2021 | 11:09 PM
4wd6.7L's Avatar
4wd6.7L
A new one? I'm familiar with one of the earlier versions of the DW TSB that included wording saying to reduce caster. That was later omitted from the newer release(s) of the TSB that I have seen.
Old Oct 8, 2021 | 08:12 AM
Norcalpr's Avatar
Norcalpr
Increase your caster, don't reduce it. I've covered this on this forum multiple times...
You only need ONE stabilizer.
Old Oct 8, 2021 | 08:55 AM
Ding126's Avatar
Ding126
depending on miles, you may need some ball joints....in addition to caster adjustments
WVsuperduty
Apr 20, 2021 09:02 PM
DL222
Jul 3, 2017 12:10 AM
cliwel
Jun 13, 2011 10:21 PM
Drawsoncad420
Jun 13, 2002 04:43 PM
