engine shaking while accelerating + rough idle
Old Oct 7, 2021 | 08:33 AM
ahmad_f150's Avatar
ahmad_f150
Hello,
(f150 2007- 4.6l- RWD)
Yesterday I had to go pick up things 40km away, Truck was idling very rough almost as it wanted to stop.
Then when i would accelerate.. engine would shake back and forth.. also when going uphill it would start shaking again...
and going downhill or taking foot off the paddle would stop shaking.
When I arrived almost to destination, on one empty road, I accelerated and rev up to 3000RPM for a long stretch.
Well on my way back truck was so normal as nothing ever happened. No shaking no rough idling...
Few days ago, I opened and cleaned up throttle body. but I drove few days after that.
Thank you
Old Oct 7, 2021 | 05:46 PM
redfishtd's Avatar
redfishtd
You need torque pro . It will tell you by cyl the raw computer counts per cyl building towards setting a misfire code . this is going to happen again .
Old Oct 7, 2021 | 07:46 PM
ahmad_f150's Avatar
ahmad_f150
I order this one today.
Amazon Amazon
It show whole bunch of fancy information.
Old Oct 8, 2021 | 02:40 PM
ahmad_f150's Avatar
ahmad_f150
So on the scanner under "on-board monitoring test"
2 things are red.
1-EGR monitoring BANK 2#32
-32.768(min) -0.578(value) -32.659(max) kPa(unit)
2- Misfire monitor Data#A1
0(min) 2.22(value) 1(max) %(unit)
Then there is cylinder data in % and counts.. I am only putting count here.
EWMA ->misfire-------------------------------> cylinder 2#A3
0(min) 25(value) 65535(max) -----> this value when to 19 when I scanned at night. I wonder if it went all the way to max--65535) and then 19
Misfare counts for last/current driving -->misfire cylinder 2#A3
0(min) 0(value) 65535(max)
EWMA ->misfire-------------------------------> cylinder 6#A7
Misfare counts for last/current driving -->misfire cylinder 6#A7
0(min) 2(value) 65535(max)------------------------------------------------------------> this when to zero when I scanned at night
Every other reading on cylinder is Zero.
Funny thing is few weeks ago I had bad spark-plug #3, there is no data about that... I guess there is no historical data stored.
Also one time 6 months ago... mechanic screwed up on board computer BCM or PCM, I think he had to replace it and had reprogrammed it.
1968F100newb
Escape & Escape Hybrid
Jun 2, 2021 10:32 AM
bayous
Jun 28, 2011 06:35 PM
YoungFordAddict66
Mar 15, 2011 11:53 AM
juang
May 22, 2004 05:59 PM
