AOD Problems
Old Oct 5, 2021 | 08:25 PM
dlpartyka's Avatar
dlpartyka
AOD Problems
My new pickup has a 302 with an AOD transmission, the shift pattern is backwards, any suggestions will be appreciated
Old Oct 5, 2021 | 08:32 PM
85e150's Avatar
85e150
Have you looked at the shifter linkage for anything obvious? I would look for a shift arm on backwards, or a shift cable attached to the wrong side of the linkage.
Does this have a proper adjusted TV cable or linkage?
Does it shift and down shift properly?
The AOD linkage and TV cable are picky and fairly complicated for an automatic.
If in doubt or if not shifting correctly, do not drive it. You can ruin an AOD in short order with a wrong TV adjustment.
One of millions of videos and links on the subject.
Old Oct 5, 2021 | 09:09 PM
dlpartyka's Avatar
dlpartyka
No cable, stock column shifter linkage I was told (Don't know if it's true I'm not previously a Ford Guy) that the shift arm can't be reversed, that was my first thought.
I forgot to mention this is a Carburated 302.
Old Oct 5, 2021 | 09:17 PM
dlpartyka's Avatar
dlpartyka
The linkage in the video is reversed of mine. Not the TV but the shift linkage itself . SO why can't I just reverse mine?
Old Oct 6, 2021 | 12:13 AM
85e150's Avatar
85e150
You may be able to. Is it the same part? Does the TV linkage end up the same? You have to adjust that TV linkage with a pressure gauge to get it right.
Old Oct 9, 2021 | 10:58 AM
dlpartyka's Avatar
dlpartyka
I found a cure for what ails me, A C4
aayoakam
May 24, 2006 01:36 PM
harpo17
May 19, 2006 06:51 AM
GEAH
Jun 29, 2002 09:06 PM
Dave Jennings
Mar 9, 2000 08:46 AM
