Alignment
Old Oct 5, 2021 | 06:02 PM
Paul Mattick's Avatar
Paul Mattick
Alignment
What do you guys think? This is on a 6.7 f250 with a 2.5” readylift level. Has the readylift trackbar drop bracket and a pmf trackbar and drag link. This is with the caster shims that carli sells installed.
Old Oct 5, 2021 | 07:21 PM
mcmurm's Avatar
mcmurm
You should have a little extra caster on the passenger side. Apparently it helps with road crown.
Old Oct 5, 2021 | 08:48 PM
morehouse7's Avatar
morehouse7
You could swap the shims for the SPC 2.3 and 2.6 degree set. This would add a little more and give you the road crown compensation. The ones Carli sells are SPC 2 degree.
How's it drive?
Old Oct 5, 2021 | 09:06 PM
Paul Mattick
How's it drive?
It drives pretty well, has a bit more bump steer since I switched to 13.5 wide tires a few weeks ago
Old Oct 5, 2021 | 09:43 PM
morehouse7's Avatar
morehouse7
Replace the stock front shocks and lower tire pressure will help soften the ride and some of the steering feedback.
Rwhjr
Jul 9, 2021 07:53 PM
AKBray907
Sep 29, 2020 06:49 PM
st1nn3tt
Dec 30, 2018 01:01 PM
my85fordIDI
Sep 20, 2010 02:57 PM
