Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
U7 Axle Code, 1985 F700
Old Oct 2, 2021 | 07:43 PM
Thunderspud's Avatar
Thunderspud
Hello! First post here. We recently picked up an F700 to use on the farm and haul steel. I'm trying to put together a folder with all the specs for our maintenance records. Looking through some of the other posts, I believe I have most of the information on the door sticker decoded, but I can't seem to find any record of the U7 axle code that's listed.....thats assuming that U7 is, in fact, the axle code and just printed off center. Attached is a snap of the door sticker with all the pertinent info.....
Can anyone shed some light on what exactly I've bought?
VIN - 1FDNF77H5FVA12421
WB - 171
Type/GVW - F770
Body - GH8Trans - SNAxle - U7
​​​​​​​AT least that's how I interpret the included image. Thanks!
Old Oct 3, 2021 | 12:46 AM
85e150's Avatar
85e150
You can go here and put the VIN in:
https://vincheck.info/check/report-s...NF77H5FVA12421
From the 1980/ MPC:
1FD = Ford Motor Co USA incomplete vehicle
N = Class 6, 19,501 to 26,000 lbs GVWR
F77 = F700 gas with 4x4 option
H = 370 V8. All versions of the 370 are covered by this code. Standard gas, low compression, LP gas, each 2BBL or 4BBL
5 = check digit
F = 1985
V = Kentucky Truck Plant
A12421 = Production sequence number
171 = 171 inch wheelbase
F770 = F700 gas 4x4 21,200 lbs GVWR (Note your tag says 24,000 lbs GVWR)
GH8 = I don't have that info. This is cab, seat, upholstery.
Trans code SN = Spicer model CM4054A five speed direct transmission
Axle code U7 = Rockwell (Timken) model H-173 single speed rear axle, 17,500lbs capacity, 6.83 ratio
141981 this appears with "DSO" printed under it.
14 = Pittsburg District Code
1981 = Special order number.
No front axle code & no paint code, so paint & front axle probably part of the special order
I have not done many decodes of 17 digit VIN trucks so if something doesn't match up, please let me know.
Old Oct 3, 2021 | 07:30 AM
Thunderspud
From the 1980/ MPC:
5 = check digit
F = 1985
Great! Thanks for looking that up. All that appears to be correct. That rear axle code was being elusive for some reason. When I searched through a bunch of old threads and found images of scans taken from parts/service manuals, none of them ever seemed to list that specific code.
Truck Guy99
Jul 29, 2014 06:48 AM
koldleblue
Oct 14, 2011 09:52 AM
Marvin882
Jan 22, 2004 05:08 PM
