Differential / Transmission
Old Oct 13, 2011 | 10:16 PM
koldleblue's Avatar
koldleblue
Question Differential / Transmission
I have a 89 F250 XLT lariat 4x4
How can i tell what diffs I have on the front and rear?
And is 2500 RPMs at 55MPH normal?
Thank you ahead of time!!!
Old Oct 14, 2011 | 04:53 AM
cjben's Avatar
cjben
there are codes on a tag on the driver's side door jam. find those codes,post them up here and someone can tell you what they are or you can look up a axle/transmission code decoder.
Old Oct 14, 2011 | 07:19 AM
88dually's Avatar
88dually
the project truck in my sig is around 2500 @55
Old Oct 14, 2011 | 08:15 AM
nstueve's Avatar
nstueve
really guys... Lets be a little more helpful
Look at the door jam sticker and the the code uner "Axle." this is what your looking for... You see the axle code circled in red "29."
Now take the code and go here:
Ford Axle Code Chart .: Articles
Old Oct 14, 2011 | 08:19 AM
cjben's Avatar
cjben
Look at the door jam sticker and the the code uner "Axle." this is what your looking for... You see the axle code circled in red "29."Now take the code and go here:
wow guess i wasn't helpful because i didn't have the fancy pictures and links even though i said the same thing you did,he just had to do a little work on his own
Old Oct 14, 2011 | 08:27 AM
88dually's Avatar
88dually
so what trans is a Z ?
Old Oct 14, 2011 | 08:51 AM
nstueve's Avatar
nstueve
Sorry didn't mean to be a dick... having the chart helps though...
Just decoded the vin off that tag and it has the 4.9L so it's Thumpers tag. Thumper has a Zf 5spd so I'm guessing ford either changed their codes or it is a wide ratio ZF.
Old Oct 14, 2011 | 09:26 AM
88dually's Avatar
88dually
i didnt know the I6 went in 250's
Old Oct 14, 2011 | 09:33 AM
nstueve's Avatar
nstueve
seems to be a common theme... yeah you can order the F250's in the 80's with the 300.
Old Oct 14, 2011 | 09:52 AM
koldleblue's Avatar
koldleblue
@nstueve
Thanks that's really helpfull !!!
97XLT4X4
Jan 23, 2011 04:33 PM
ctrain22
Oct 31, 2007 02:15 AM
Marvin882
Jan 22, 2004 05:08 PM
