driveshaft phasing help
Old Oct 1, 2021 | 01:35 PM
msalander's Avatar
msalander
Thanks so much guys. With the driveshaft out and the wheels on the ground, should I be able to turn the pinion yoke at all? Right now I am able to rotate it a few degrees in either direction.
Old Oct 1, 2021 | 01:50 PM
smle's Avatar
smle
That sounds right.
Old Oct 1, 2021 | 01:58 PM
redroad's Avatar
redroad
The slop you're having at the pinion yoke is normal for a Truck with a 150.000 miles on it.
Just in case
If you take the two bolts loose from the carrier bearing you can phase the shaft at the slip yoke . Put a jack stand under the rear shaft at about where the slip yoke u-joint is at the carrier bearing height. Now you with the shafts phased you can connect to the back of the T-18 rotating the T-18's yoke with it in neutral to match the drive shaft and you have flexibility in length with the carrier bearing loose. Once your shaft is connected to the T-18 secure the carrier bearing again and your done. A good time to grease anything with grease zerks like u-joints etc. and then your ready for a test drive. Post back with any questions or progress.
Old Oct 3, 2021 | 02:14 PM
msalander's Avatar
msalander
Thanks so much for all your help guys! I don't know if it's "perfect" but my 35 mph shimmy is gone, all u-joints replaced, and I can cruise at highway speeds without much vibration. Don't know what I'd do without this forum to help keep my '77 on the road and my daily driver! Thanks so much again!
Old Sep 10, 2022 | 12:13 AM
msalander's Avatar
msalander
I brought my driveshaft to a pro shop and it's fixed. They had to cut and reweld the slip/coupling yoke in order to get the shaft in phase completely. It cost me $280 and my howl/growl at highway speeds is gone. I got it back today and have had only 1 test drive so far. Thanks for everyone's patience, ideas, and help.
Tmad
Apr 15, 2017 11:22 AM
Spitfire44
Jul 13, 2010 12:41 PM
Kuskoal
Nov 1, 2008 11:30 AM
harmdogg1978
Sep 27, 2004 10:25 AM
Simple Man
Aug 29, 2004 03:55 PM
