351w Machining?
Old Sep 29, 2021 | 06:41 PM
Justr24's Avatar
Justr24
351w Machining?
I've got a 351w out of a 1977 Cougar. I'm getting ready to drop it into a ranger. I'm checking to see if I need to take this to a machine shop, or if I can clean it up myself and continue the rebuild. Piston heads and cylinder walls all appear okay, but the rust here is concerning to me. I think it's from the rings.
Any input would be appreciated
Thanks!
-Justin
File Type: html
PXL_20210929_231341244.html (633 Bytes, 25 views)
Old Sep 29, 2021 | 06:49 PM
85e150's Avatar
85e150
Picture isn't working.
Old Sep 29, 2021 | 07:02 PM
Justr24's Avatar
Justr24
Thanks!
-Justin
Old Sep 29, 2021 | 07:04 PM
Justr24's Avatar
Justr24
Sorry about that! Just put it in the replies to this post.
Thanks for letting me know!
-Justin
Old Sep 29, 2021 | 07:10 PM
85e150's Avatar
85e150
Clean it up it should be OK.
A stock '77 would be a low compression low power engine, so if you're after a real hot rod an OEM engine isn't the answer. Also, the 351W is a tighter fit in a Ranger where the 302 goes in without too much trouble.
All things considered, the extra work to get the 351W in there is not worth the effort if you are talking a stock motor.
jmo but search it out as far as power and the fitting of a 351W into a Ranger.
Old Sep 29, 2021 | 07:24 PM
Justr24's Avatar
Justr24
I'm planning on changing out the cam, putting some tighter springs on the heads, and adding an electronic ignition system. I'm gonna be changing out the intake as well, making it a 4-barrel. I'm not sure exactly how much that's gonna help, but would that make it at least a bit more worth it? I don't have much experience with the Small block windsor, most of my experience is on the FE block 352.
Thanks,
-Justin
Old Sep 29, 2021 | 10:27 PM
85e150's Avatar
85e150
Check the compression ratio. The cam is a big deal, but so are the heads and compression.
Conanski has the entire SBF run memorized, so maybe he will be by with some advice.
rwrogers
Mar 3, 2014 04:30 PM
ozblitz
Jan 19, 2010 01:21 PM
HangGlider
Apr 22, 2003 02:39 PM
JTY
Sep 15, 2002 12:56 PM
